소개
This guide will instruct you how to disassemble the speaker in order to replace the battery. It's a task that shouldn't take longer than 30 minutes and has a moderate difficulty.
필요한 것
Remove the speaker case from the outer casing by prying it from the base of the speaker using a metal spudger.
다른 10명이 해당 안내서를 완성하였습니다.
댓글 11개
Where can I purchase a replacement battery
Did you find the battery to this
Brother you made my day…
I just finish your tutorial…thanks a
Hi Pepe, where do i get the wright Batterie, what was your exact artikel? U cant find the ones mentioned in the manual… Thank you!!
where can i purchase the new battery
ieezy naga - 답글
