주요 콘텐츠로 건너뛰기
Sony SRS-XE200 Charging Port Replacement
필요한 것
  1. Sony SRS-XE200 Charging Port Replacement, Speaker Assembly: 1 단계, 이미지 1/2 Sony SRS-XE200 Charging Port Replacement, Speaker Assembly: 1 단계, 이미지 2/2
    • Pry the outer cover of the speaker from the body using a spudger.
    • A clicking noise can be heard as the cover is detaching.
  2. Sony SRS-XE200 Charging Port Replacement: 2 단계, 이미지 1/1
    • Pry the rubber cap away from the body of the speaker using a spudger.
  3. Sony SRS-XE200 Charging Port Replacement: 3 단계, 이미지 1/2 Sony SRS-XE200 Charging Port Replacement: 3 단계, 이미지 2/2
    • Remove the eight 1 mm screws that connect the motherboard case and the speaker case with a Phillips #1 screwdriver.
    • Remove the four 0.8 mm screws that connect the motherboard case and the speaker case with a Phillips #1 screwdriver.
  4. Sony SRS-XE200 Charging Port Replacement: 4 단계, 이미지 1/2 Sony SRS-XE200 Charging Port Replacement: 4 단계, 이미지 2/2
    • Unplug the colored wires from the motherboard to detach the speaker assembly.
  5. Sony SRS-XE200 Charging Port Replacement, Battery: 5 단계, 이미지 1/3 Sony SRS-XE200 Charging Port Replacement, Battery: 5 단계, 이미지 2/3 Sony SRS-XE200 Charging Port Replacement, Battery: 5 단계, 이미지 3/3
    • Remove the five 1 mm screws connecting the motherboard to the case with a Phillips #1 screwdriver.
    • Separate the motherboard from the case.
  6. Sony SRS-XE200 Charging Port Replacement: 6 단계, 이미지 1/3 Sony SRS-XE200 Charging Port Replacement: 6 단계, 이미지 2/3 Sony SRS-XE200 Charging Port Replacement: 6 단계, 이미지 3/3
    • Remove the battery from the battery holder with a nylon spudger.
    • Unplug the battery from the motherboard.
  7. Sony SRS-XE200 Charging Port Replacement, Charging Port: 7 단계, 이미지 1/2 Sony SRS-XE200 Charging Port Replacement, Charging Port: 7 단계, 이미지 2/2
    • Remove the charging port.
결론
Vishant Savaliya
회원 가입일: 02/09/23
361 평판
안내서 4개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 14
전체 시간: 345
