주요 콘텐츠로 건너뛰기
Sony SRS-XE200 Speaker Assembly Replacement
필요한 것
  1. Sony SRS-XE200 Speaker Assembly Replacement, Speaker Assembly: 1 단계, 이미지 1/2 Sony SRS-XE200 Speaker Assembly Replacement, Speaker Assembly: 1 단계, 이미지 2/2
    • Pry the outer cover of the speaker from the body using a spudger.
    • A clicking noise can be heard as the cover is detaching.
  2. Sony SRS-XE200 Speaker Assembly Replacement: 2 단계, 이미지 1/1
    • Pry the rubber cap away from the body of the speaker using a spudger.
  3. Sony SRS-XE200 Speaker Assembly Replacement: 3 단계, 이미지 1/2 Sony SRS-XE200 Speaker Assembly Replacement: 3 단계, 이미지 2/2
    • Remove the eight 1 mm screws that connect the motherboard case and the speaker case with a Phillips #1 screwdriver.
    • Remove the four 0.8 mm screws that connect the motherboard case and the speaker case with a Phillips #1 screwdriver.
  4. Sony SRS-XE200 Speaker Assembly Replacement: 4 단계, 이미지 1/2 Sony SRS-XE200 Speaker Assembly Replacement: 4 단계, 이미지 2/2
    • Unplug the colored wires from the motherboard to detach the speaker assembly.
결론
Kristen Gismondi
회원 가입일: 11/12/14
85,242 평판
안내서 215개 작성하였습니다
iFixit iFixit 회원
Staff
140 회원들
안내서 18,076개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 13
전체 시간: 170
