주요 콘텐츠로 건너뛰기
Sony Smart Watch SW2 Wristband Link Replacement
필요한 것
  1. Sony Smart Watch SW2 Wristband Link Replacement, Wristband: 1 단계, 이미지 3개 중 1개 Sony Smart Watch SW2 Wristband Link Replacement, Wristband: 1 단계, 이미지 3개 중 2개 Sony Smart Watch SW2 Wristband Link Replacement, Wristband: 1 단계, 이미지 3개 중 3개
    • Use SIM Eject tool for an apple phone or the one iFixit sells to push the pin out to the other side.
    • Please proceed slowly and carefully, DON'T push too hard or fast because the tip of the SIM Eject is very sharp which can cause an Injury.
    • Set aside the pin in a safe place.
  2. Sony Smart Watch SW2 Wristband Link Replacement: 2 단계, 이미지 1개 중 1개
    • Now, the band size is adjustable.
    • Flip the band over. Notice that there are some arrows to follow in order for you to push the pin out of the pocket.
  3. Sony Smart Watch SW2 Wristband Link Replacement: 3 단계, 이미지 2개 중 1개 Sony Smart Watch SW2 Wristband Link Replacement: 3 단계, 이미지 2개 중 2개
    • Following the arrow, and push the pin out to the other side carefully.
  4. Sony Smart Watch SW2 Wristband Link Replacement: 4 단계, 이미지 1개 중 1개
    • Now, you are to choose how many links to remove for the desired size to fit your wrist.
    • After adjusting the size of the band, attach back the link shown in the picture only with the first pin we got out at the very beginning of the guide.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Mohammed Alshamrani
회원 가입일: 03/21/18
205 평판
안내서 2개를 작성함
IUPUI, Team S2-G2, Freund Spring 2018 IUPUI, Team S2-G2, Freund Spring 2018 회원
IUPUI-FREUND-S18S2G2
3 회원들
안내서 2개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 3
지난 30일: 6
전체 시간: 709
