주요 콘텐츠로 건너뛰기
Sony TCM-919 Cassette-Corder Operating Buttons Replacement
필요한 것
  1. Sony TCM-919 Cassette-Corder Operating Buttons Replacement, Remove Back Cover: 1 단계, 이미지 1/1
    • Turn the device around so that the back cover if facing upward. Use your thumbs to press firmly down and then push the battery door cover open.
    • Remove any batteries.
  2. Sony TCM-919 Cassette-Corder Operating Buttons Replacement, Back Cover Screw Removal: 2 단계, 이미지 1/1
    • Remove the 5 5.95mm screws as indicated in the picture with the Phillips Head screwdriver.
  3. Sony TCM-919 Cassette-Corder Operating Buttons Replacement, Locate Buttons: 3 단계, 이미지 1/1
    • Look to the back of the top cover and locate the broken button(s).
  4. Sony TCM-919 Cassette-Corder Operating Buttons Replacement, Detach Buttons: 4 단계, 이미지 1/2 Sony TCM-919 Cassette-Corder Operating Buttons Replacement, Detach Buttons: 4 단계, 이미지 2/2
    • Use a splunger tool to undo the two clips that belong to any broken buttons.
    • Turn the device over and using your finger, push out the loose button.
결론
Marygayle Martin
회원 가입일: 10/23/14
506 평판
안내서 5개 작성하였습니다
Baylor, Team 4-3, Williams Fall 2014 Baylor, Team 4-3, Williams Fall 2014 회원
BU-WILLIAMS-F14S4G3
3 회원들
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 6
30일 전: 7
전체 시간: 823
