주요 콘텐츠로 건너뛰기
Sony Tablet S Factory / Hard reset
동영상 개요
  1. Sony Tablet S Factory / Hard reset, Sony Tablet S Factory / Hard reset: 1 단계, 이미지 1/3 Sony Tablet S Factory / Hard reset, Sony Tablet S Factory / Hard reset: 1 단계, 이미지 2/3 Sony Tablet S Factory / Hard reset, Sony Tablet S Factory / Hard reset: 1 단계, 이미지 3/3
    • Metod 1:
    • - Settings
    • - Backup & reset
    • - Factory data reset
    • The tablet will restart automatically.
    • !!! From the "Backup & reset" menu you can do Back up my data !!!
  2. Sony Tablet S Factory / Hard reset: 2 단계, 이미지 1/3 Sony Tablet S Factory / Hard reset: 2 단계, 이미지 2/3 Sony Tablet S Factory / Hard reset: 2 단계, 이미지 3/3
    • Metod 2:
    • Power of the tablet. Pres and hold the Power On key and the Volume Up key at the same time.
    • When you see the Sony logo release the Power On button but continue to press the Volume Up button.
    • Now you are in the Android recovery menu. Use Volume keys to scroll and the Power On key to select. From the options select:
    • - Reset to Factory Settings
    • - Yes - erase all user data
    • - The tablet will restart alone
    • Please SUBSCRIBE to my channel ツ
결론
다른 19명이 해당 안내서를 완성하였습니다.
ZFix
회원 가입일: 12/09/13
191,882 평판
안내서 330개 작성하였습니다
Master Techs Master Techs 회원
Community
321 회원들
안내서 1,516개 작성하였습니다
댓글 23개
Hallo , I follow the steps , nothing is happening . Exists a different way ? dedudan@yahoo.com
Dedu Octavian - 답글
hi man
i do but its very VERY specific
press power
when te white led upper power flash on quiqkly relase power and press vol up..........
when the display make a very litle flash relase the vol buton
ENJOY AND GIVE THANKS
tunerlezoart4everx -
Hi, you are my knight in shining armour. You were right, it´s incredibly specific. You have to watch the white light above the power button and be plugged in into a socket. Nobody else mentioned the little white light, I was close to believe my tablet was defect.
Thank you very, very much.
Kat Hutnik -
than q
very use ful
kameswar - 답글
ive tried it many times but still is stuck on sony logo
fish luv72 - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 6
30일 전: 65
전체 시간: 86,611
