주요 콘텐츠로 건너뛰기
Sony Tablet S Front Camera Replacement
필요한 것
  1. Sony Tablet S Front Camera Replacement, Battery: 1 단계, 이미지 2개 중 1개 Sony Tablet S Front Camera Replacement, Battery: 1 단계, 이미지 2개 중 2개
    • Ensure that the device is completely turned off before attempting a repair. The battery may still have charge; use caution touching the components.
    • Use a plastic opening tool to remove the two rubber grips on the back of the tablet.
  2. Sony Tablet S Front Camera Replacement: 2 단계, 이미지 1개 중 1개
    • Remove the two 10mm Phillips #0 screws located under the grips.
  3. Sony Tablet S Front Camera Replacement: 3 단계, 이미지 2개 중 1개 Sony Tablet S Front Camera Replacement: 3 단계, 이미지 2개 중 2개
    • Flip the tablet over and use a plastic opening tool to pry the casing away from the top of the screen. Push the back cover off.
    • There is adhesive holding the case on located at the top of the screen. Push the casing toward the top of the screen while also wiggling it back and forth.
  4. Sony Tablet S Front Camera Replacement: 4 단계, 이미지 1개 중 1개
    • Once the casing is off, remove the nine 5mm Phillips #0 screws shown.
  5. Sony Tablet S Front Camera Replacement: 5 단계, 이미지 1개 중 1개
    • Remove the white ribbon cable by pulling the blue tab straight up out of the socket and then peeling up the tape securing it to the tablet.
    • Use caution when removing the cable, as the socket is very fragile.
  6. Sony Tablet S Front Camera Replacement: 6 단계, 이미지 1개 중 1개
    • Remove the copper ribbon cable by gently using a spudger to pry it up from its socket.
  7. Sony Tablet S Front Camera Replacement: 7 단계, 이미지 1개 중 1개
    • Slide the bottom grey cover piece away from the body and remove it.
    • If this piece gives resistance, use a spudger on the sides of the tablet to pry it loose.
  8. Sony Tablet S Front Camera Replacement: 8 단계, 이미지 1개 중 1개
    • Remove the five 4mm Phillips #000 screws.
    • Remove the two 5mm Phillips #000 screws holding the charger in place.
  9. Sony Tablet S Front Camera Replacement: 9 단계, 이미지 3개 중 1개 Sony Tablet S Front Camera Replacement: 9 단계, 이미지 3개 중 2개 Sony Tablet S Front Camera Replacement: 9 단계, 이미지 3개 중 3개
    • Position the charging port at an angle so you can thread it through the opening as you remove the black plastic cover from the back of the tablet.
    • If the cover is not coming off easily, use a plastic opening tool to pry it loose from the edges of the screen.
  10. Sony Tablet S Front Camera Replacement: 10 단계, 이미지 2개 중 1개 Sony Tablet S Front Camera Replacement: 10 단계, 이미지 2개 중 2개
    • Use a spudger to lift the zero insertion force connector latch for the long ribbon cable to the right of the battery, then pull the cable loose from its socket.
  11. Sony Tablet S Front Camera Replacement: 11 단계, 이미지 1개 중 1개
    • Remove the three 5mm Phillips #0 screws securing the original battery.
  12. Sony Tablet S Front Camera Replacement: 12 단계, 이미지 2개 중 1개 Sony Tablet S Front Camera Replacement: 12 단계, 이미지 2개 중 2개
    • Use the spudger to pop the battery loose and remove the battery.
  13. Sony Tablet S Front Camera Replacement, Front Camera: 13 단계, 이미지 1개 중 1개
    • Remove the single 5mm #0 Philips screw.
  14. Sony Tablet S Front Camera Replacement: 14 단계, 이미지 1개 중 1개
    • Remove the camera assembly.
결론
작성자
1다른 기여자 명과 함께
Austin Mann
회원 가입일: 09/28/16
287 평판
안내서 5개를 작성함
USF Tampa, Team 3-5, Passmore Fall 2016 USF Tampa, Team 3-5, Passmore Fall 2016 회원
USFT-PASSMORE-F16S3G5
3 회원들
안내서 5개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 5
지난 30일: 11
전체 시간: 661
