주요 콘텐츠로 건너뛰기
Sony Tablet S Rear Camera Replacement
필요한 것
  1. Sony Tablet S Rear Camera Replacement, Rear Camera: 1 단계, 이미지 1/2 Sony Tablet S Rear Camera Replacement, Rear Camera: 1 단계, 이미지 2/2
    • Ensure that the device is completely turned off before attempting a repair. The battery may still have charge; use caution touching the components.
    • Use a plastic opening tool to remove the two rubber grips on the back of the tablet.
  2. Sony Tablet S Rear Camera Replacement: 2 단계, 이미지 1/1
    • Remove the two 10mm Phillips #0 screws located under the grips.
  3. Sony Tablet S Rear Camera Replacement: 3 단계, 이미지 1/2 Sony Tablet S Rear Camera Replacement: 3 단계, 이미지 2/2
    • Flip the tablet over and use a plastic opening tool to pry the casing away from the top of the screen. Push the back cover off.
    • There is adhesive holding the case on located at the top of the screen. Push the casing toward the top of the screen while also wiggling it back and forth.
  4. Sony Tablet S Rear Camera Replacement: 4 단계, 이미지 1/1
    • Remove the copper ribbon cable by gently using a spudger to pry it up from its socket.
    • Use caution when removing the cable, as the socket is very fragile.
  5. Sony Tablet S Rear Camera Replacement: 5 단계, 이미지 1/2 Sony Tablet S Rear Camera Replacement: 5 단계, 이미지 2/2
    • Use a finger or a spudger to pull on camera housing.
  6. Sony Tablet S Rear Camera Replacement: 6 단계, 이미지 1/1
    • Remove the assembly from the plastic shielding.
결론
Austin Mann
회원 가입일: 09/28/16
287 평판
안내서 5개 작성하였습니다
USF Tampa, Team 3-5, Passmore Fall 2016 USF Tampa, Team 3-5, Passmore Fall 2016 회원
USFT-PASSMORE-F16S3G5
3 회원들
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 8
전체 시간: 369
