소개
To replace the Wi-Fi card, Bluetooth card, and button control unit, the front cover must be removed in order to access those parts.
Please make sure that the device is unplugged and completely powered down before trying to take the Front Panel off.
필요한 것
Use a Phillips #2 screwdriver to remove the two 10.5 mm screws that secure the two side panels onto the back of the player.
Slide both covers back about a 1/2 inch, then pull them away from the case.
Toward the panel there is a ribbon cable with 4 small black pieces of tape holding it down
Pull directly up on the ribbon cable to disconnect it from the motherboard
Gently pull the cable back away from the motherboard pulling the tape off with it
