주요 콘텐츠로 건너뛰기
Sony VAIO VPCEC1M1E Keyboard Replacement
필요한 것
  1. Sony VAIO VPCEC1M1E Keyboard Replacement, Keyboard: 1 단계, 이미지 1/1
    • Remove the following color-coded screws:
    • These screws secure the RAM and hard drive covers, respectively.
    • These screws secure the optical drive to the lower case of the laptop.
    • The various other screws highlighted in the picture are unnecessary to remove and should be done at your own discretion.
  2. Sony VAIO VPCEC1M1E Keyboard Replacement: 2 단계, 이미지 1/1
    • Remove the following screws:
    • Five screws highlighted in orange.
    • Two screws highlighted in blue.
    • Pry the hard drive connector upwards from its socket on the logic board.
  3. Sony VAIO VPCEC1M1E Keyboard Replacement: 3 단계, 이미지 1/1
    • Release the highlighted clips to remove the upper case of the keyboard.
  4. Sony VAIO VPCEC1M1E Keyboard Replacement: 4 단계, 이미지 1/3 Sony VAIO VPCEC1M1E Keyboard Replacement: 4 단계, 이미지 2/3 Sony VAIO VPCEC1M1E Keyboard Replacement: 4 단계, 이미지 3/3
    • Flip up the retaining flap (highlighted in red) on the keyboard ribbon cable ZIF socket.
    • Be sure you are prying up on the hinged retaining flap and not the socket itself.
    • Pull the keyboard ribbon cable straight out of its socket toward the front edge of the laptop.
결승점
다른 7명이 해당 안내서를 완성하였습니다.
Stephan
회원 가입일: 08/20/11
199 평판
안내서 1개 작성함
댓글 3개
Very useful, thank you. A real pain to do though without snapping the plastic tabs on the upper case.
Eddie B - 답글
OMG... guys, you need just unscrew FOUR screws on the bottom (two orange circles on the same level that yellow sticker and two orange-circled screws in the middle of left and right side) and then pop the keyboard up with knife, etc, and disconnect the cable.
Paul G - 답글
agree with Paul G. you don’t need to remove all the plastic case to change the keyboard
Pierret -
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 8
30일 전: 24
전체 시간: 23,004
