주요 콘텐츠로 건너뛰기
Sony VAIO PCG-933A Battery Replacement
  1. Sony VAIO PCG-933A Battery Replacement, Battery: 1 단계, 이미지 1/2 Sony VAIO PCG-933A Battery Replacement, Battery: 1 단계, 이미지 2/2
    • Turn the laptop upside down so that the top is sitting on a flat surface.
    • If you are looking at the bottom of the laptop the battery is located on the front right side of the laptop; the opposite side from the floppy disk drive.
  2. Sony VAIO PCG-933A Battery Replacement: 2 단계, 이미지 1/3 Sony VAIO PCG-933A Battery Replacement: 2 단계, 이미지 2/3 Sony VAIO PCG-933A Battery Replacement: 2 단계, 이미지 3/3
    • As shown by the arrow, slide the plastic cover up and then pull out and downwards.
    • You should now be able to pull the battery out.
결론
Sara Lillard
회원 가입일: 04/11/11
165 평판
안내서 8개 작성하였습니다
Cal Poly, Team 12-36, Maness Spring 2011 Cal Poly, Team 12-36, Maness Spring 2011 회원
CPSU-MANESS-S11S12G36
4 회원들
안내서 16개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 5
전체 시간: 1,558
