소개
This repair guide shows how to replace and clean out the fan.
필요한 것
Turn the laptop upside down so that the top is sitting on a flat surface.
If you are looking at the bottom of the laptop the battery is located on the front right side of the laptop; the opposite side from the floppy disk drive.
Remove the four 16 mm screws bordering the edge of the laptop using a Phillips #0 screwdriver.
다른 한 분이 해당 안내서를 완성하였습니다.
