주요 콘텐츠로 건너뛰기
기기를 고치세요
수리할 권리
부품 & 도구
소개
This repair guide illustrates how to replace the Floppy Disk Drive.
  1. Turn the laptop upside down The battery is located on the front right side of the laptop; the opposite side from the floppy disk drive.
    • Turn the laptop upside down
    • The battery is located on the front right side of the laptop; the opposite side from the floppy disk drive.
  2. As shown by the arrow, slide the plastic cover up and then pull out and downwards. You should now be able to pull the battery out. You should now be able to pull the battery out.
    • As shown by the arrow, slide the plastic cover up and then pull out and downwards.
    • You should now be able to pull the battery out.
  3. Nintendo Switch 키트
    게임으로 돌아가기 위한 빠른 해결책
    Nintendo Switch 키트 쇼핑하기
    Nintendo Switch 키트
    게임으로 돌아가기 위한 빠른 해결책
  4. With the laptop facing you, turn the laptop upside down.
    • With the laptop facing you, turn the laptop upside down.
  5. Locate the release switch in the center of the laptop, shown here. Slide the switch, and hold in place.  The floppy disk drive is now free and should easily slide out. Slide the switch, and hold in place.  The floppy disk drive is now free and should easily slide out.
    • Locate the release switch in the center of the laptop, shown here.
    • Slide the switch, and hold in place. The floppy disk drive is now free and should easily slide out.
  6. To replace, insert the new floppy disk drive with the wording facing down.
    • To replace, insert the new floppy disk drive with the wording facing down.
결론
Sara Lillard
회원 가입일: 2011년 04월 11일
141 평판
안내서 8개 작성하였습니다
Cal Poly, Team 12-36, Maness Spring 2011 Cal Poly, Team 12-36, Maness Spring 2011 회원
CPSU-MANESS-S11S12G36
4 회원들
안내서 8개 작성하였습니다
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 6
전체 시간: 1,681
