주요 콘텐츠로 건너뛰기
Sony VAIO PCG-F360 Speaker Panel Replacement
필요한 것
  1. Sony VAIO PCG-F360 Speaker Panel Replacement, Battery: 1 단계, 이미지 1/1
    • Position the laptop screen-side down as shown.
    • In this position the battery housing will be located on the right hand side.
  2. Sony VAIO PCG-F360 Speaker Panel Replacement: 2 단계, 이미지 1/1
    • Lift the panel up and then out to gain access to the battery.
  3. Sony VAIO PCG-F360 Speaker Panel Replacement: 3 단계, 이미지 1/1
    • Use the indentations to pull the old battery out.
  4. Sony VAIO PCG-F360 Speaker Panel Replacement: 4 단계, 이미지 1/1
    • The battery is now removed and it is safe to move on to uninstalling other components.
  5. Sony VAIO PCG-F360 Speaker Panel Replacement, Speaker Panel: 5 단계, 이미지 1/3 Sony VAIO PCG-F360 Speaker Panel Replacement, Speaker Panel: 5 단계, 이미지 2/3 Sony VAIO PCG-F360 Speaker Panel Replacement, Speaker Panel: 5 단계, 이미지 3/3
    • There are two screws on the left hand side of the laptop near the IR receiver. remove them using a #00 Philips head screwdriver.
    • Slide the speaker panel towards the left, then carefully flip it over onto the keyboard.
    • Make sure not to pull the speaker panel away from the computer just yet - it is still connected!
  6. Sony VAIO PCG-F360 Speaker Panel Replacement: 6 단계, 이미지 1/3 Sony VAIO PCG-F360 Speaker Panel Replacement: 6 단계, 이미지 2/3 Sony VAIO PCG-F360 Speaker Panel Replacement: 6 단계, 이미지 3/3
    • Push the beige tab in the direction of the ribbon. it should only move a small amount
    • Remove the ribbon by gently pulling on it, there should be little or no resistance.
    • Now the speaker panel can be set aside.
결론
Hannah Millea
회원 가입일: 03/11/14
401 평판
안내서 4개 작성하였습니다
UMass Dartmouth, Team 3-5, Calaway Spring 2014 UMass Dartmouth, Team 3-5, Calaway Spring 2014 회원
UMASSD-CALAWAY-S14S3G5
2 회원들
안내서 4개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 1
30일 전: 10
전체 시간: 181
