주요 콘텐츠로 건너뛰기
Sony VAIO SVE14AJ16L RAM Replacement
필요한 것
  1. Sony VAIO SVE14AJ16L RAM Replacement, RAM: 1 단계, 이미지 1/1
    • Turn your laptop off before starting.
    • Turn the laptop upside down onto the closed lid so that the bottom is facing you.
  2. Sony VAIO SVE14AJ16L RAM Replacement: 2 단계, 이미지 1/2 Sony VAIO SVE14AJ16L RAM Replacement: 2 단계, 이미지 2/2
    • Locate and remove the lone screw on the RAM cover with a Phillips #0 head screw driver.
    • Carefully pry the RAM cover up.
    • There will be some resistance, so use strength and not speed to remove the cover.
  3. Sony VAIO SVE14AJ16L RAM Replacement: 3 단계, 이미지 1/3 Sony VAIO SVE14AJ16L RAM Replacement: 3 단계, 이미지 2/3 Sony VAIO SVE14AJ16L RAM Replacement: 3 단계, 이미지 3/3
    이 단계에 사용된 도구:
    iFixit Opening Tool
    $1.99
    구매
    • With the cover removed, peel back the black protective plastic to expose one of the two RAM sticks.
    • Make sure not to touch any part of the blue board itself, and only handle the stick from it's edges.
    • Gently, but firmly push back the two side anchors that hold in the RAM using either an iFixit Opening Tool or your fingernails.
  4. Sony VAIO SVE14AJ16L RAM Replacement: 4 단계, 이미지 1/2 Sony VAIO SVE14AJ16L RAM Replacement: 4 단계, 이미지 2/2
    • Once both anchors are released from the RAM stick, the stick will spring up at an angle
    • Finally, carefully pull the RAM stick away from the laptop at the same angle it is sitting at.
결론
Dustin Smith
회원 가입일: 09/21/18
236 평판
안내서 2개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 5
30일 전: 7
전체 시간: 539
