주요 콘텐츠로 건너뛰기
Sony VAIO SVE14AJ16L Wireless Network Card Replacement
필요한 것
  1. Sony VAIO SVE14AJ16L Wireless Network Card Replacement, Wireless Network Card: 1 단계, 이미지 1/1
    • Remove the twelve 5 mm Phillips #0 screws from the bottom of the laptop.
  2. Sony VAIO SVE14AJ16L Wireless Network Card Replacement: 2 단계, 이미지 1/1
    • Remove the two 5 mm Phillips #0 screws from the bottom of the laptop.
  3. Sony VAIO SVE14AJ16L Wireless Network Card Replacement: 3 단계, 이미지 1/1
    • Using the plastic prying tools, go around the edge of the bottom of the laptop to release the cover.
  4. Sony VAIO SVE14AJ16L Wireless Network Card Replacement: 4 단계, 이미지 1/1
    • Disconnect the black and white antenna wires from the wifi card.
    • Make sure to lift the plugs straight up from the sockets and not from an angle.
  5. Sony VAIO SVE14AJ16L Wireless Network Card Replacement: 5 단계, 이미지 1/2 Sony VAIO SVE14AJ16L Wireless Network Card Replacement: 5 단계, 이미지 2/2
    • Remove the 3 mm Phillips #0 screw from the wifi card.
    • Remove the card from its socket.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Alex Pham
회원 가입일: 09/28/18
207 평판
안내서 1개 작성함
댓글 2개
Perfect hardware guide, but i make this and windows 10 recognizes the card, but does not start the Wifi, my laptop SVE14A2X1EW does not have wifi switch or Fn buttons, and I have no way to enable the wifi, some trick?
VirusBCN - 답글
Please follow this guide to enable wifi and bluetooth on this device for any modern wifi card:
gsid.in/using-old-mini-pcie-wlan-cards-in-modern-laptops/
Daniel - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 8
30일 전: 21
전체 시간: 2,434
