주요 콘텐츠로 건너뛰기
Sony VAIO VGN-FW 590 Battery Replacement
필요한 것
  1. Sony VAIO VGN-FW 590 Battery Replacement, Battery: 1 단계, 이미지 1/2 Sony VAIO VGN-FW 590 Battery Replacement, Battery: 1 단계, 이미지 2/2
    • Turn the computer off, close the LCD screen, and insure the computer is unplugged from any outlet.
    • Turn the computer over so that the bottom of the computer is facing up and the "screen swivels" (DC in port and On button) are facing away from you.
    • Locate the battery pack between the two "screen swivels" at the top of the computer back.
  2. Sony VAIO VGN-FW 590 Battery Replacement: 2 단계, 이미지 1/2 Sony VAIO VGN-FW 590 Battery Replacement: 2 단계, 이미지 2/2
    • Locate two sliding release switches below the battery pack.
    • Slide the "Lock" release to the right toward the center of the computer.
    • Slide the "Release" switch to the left, toward the center of the computer. It must be held in place because it is spring loaded.
  3. Sony VAIO VGN-FW 590 Battery Replacement: 3 단계, 이미지 1/2 Sony VAIO VGN-FW 590 Battery Replacement: 3 단계, 이미지 2/2
    • While holding the "Release" switch toward the center of the computer, press on the raised portion of the battery pack away from you. The battery pack will pop up.
    • Once the battery pack has popped out of its compartment, lift it out of the computer.
결론
Morton Wakeland
회원 가입일: 10/30/17
101 평판
안내서 1개 작성함
University of North Texas, Team S1-G3, Boettger Fall 2017 University of North Texas, Team S1-G3, Boettger Fall 2017 회원
UNT-BOETTGER-F17S1G3
3 회원들
안내서 10개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 7
30일 전: 18
전체 시간: 806
