주요 콘텐츠로 건너뛰기
Sony VAIO VGN-FW 590 Keyboard Key Replacement
필요한 것
  1. Sony VAIO VGN-FW 590 Keyboard Key Replacement, Keyboard Key: 1 단계, 이미지 1/1
    • Open your computer.
    • Make sure the computer is turned off.
  2. Sony VAIO VGN-FW 590 Keyboard Key Replacement: 2 단계, 이미지 1/1
    • Find the broken key.
    • The S key is our example though it is not broken.
  3. Sony VAIO VGN-FW 590 Keyboard Key Replacement: 3 단계, 이미지 1/2 Sony VAIO VGN-FW 590 Keyboard Key Replacement: 3 단계, 이미지 2/2
    • Insert the plastic spudger underneath the edge of the key.
    • Lift the key until it pops off on all four corners. There should be a white plastic base underneath the key.
  4. Sony VAIO VGN-FW 590 Keyboard Key Replacement: 4 단계, 이미지 1/1
    • Orient replacement key over the white plastic base, so it is aligned properly with the other keys.
    • Press the replacement key firmly in the center until it is completely depressed and attached to the key base.
  5. Sony VAIO VGN-FW 590 Keyboard Key Replacement: 5 단계, 이미지 1/1
    • Test the key by releasing the key. It should pop up and look like the rest of the keys on the keyboard.
결론
Congratulations! You have successfully replaced a key on your keyboard.
Jennifer Pache
회원 가입일: 10/30/17
304 평판
안내서 3개 작성하였습니다
University of North Texas, Team S1-G3, Boettger Fall 2017 University of North Texas, Team S1-G3, Boettger Fall 2017 회원
UNT-BOETTGER-F17S1G3
3 회원들
안내서 10개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 4
30일 전: 15
전체 시간: 1,485
