주요 콘텐츠로 건너뛰기
Sony VAIO VGN-FW 590 Keyboard Replacement
필요한 것
  1. Sony VAIO VGN-FW 590 Keyboard Replacement, Battery: 1 단계, 이미지 1/2 Sony VAIO VGN-FW 590 Keyboard Replacement, Battery: 1 단계, 이미지 2/2
    • Turn the computer off, close the LCD screen, and insure the computer is unplugged from any outlet.
    • Turn the computer over so that the bottom of the computer is facing up and the "screen swivels" (DC in port and On button) are facing away from you.
    • Locate the battery pack between the two "screen swivels" at the top of the computer back.
  2. Sony VAIO VGN-FW 590 Keyboard Replacement: 2 단계, 이미지 1/2 Sony VAIO VGN-FW 590 Keyboard Replacement: 2 단계, 이미지 2/2
    • Locate two sliding release switches below the battery pack.
    • Slide the "Lock" release to the right toward the center of the computer.
    • Slide the "Release" switch to the left, toward the center of the computer. It must be held in place because it is spring loaded.
  3. Sony VAIO VGN-FW 590 Keyboard Replacement: 3 단계, 이미지 1/2 Sony VAIO VGN-FW 590 Keyboard Replacement: 3 단계, 이미지 2/2
    • While holding the "Release" switch toward the center of the computer, press on the raised portion of the battery pack away from you. The battery pack will pop up.
    • Once the battery pack has popped out of its compartment, lift it out of the computer.
  4. Sony VAIO VGN-FW 590 Keyboard Replacement, Keyboard: 4 단계, 이미지 1/1
    • Remove the circled screws using the Phillips #0 screwdriver.
    • The outer two screws are 7.7mm
    • The center two screws are 2.5mm
    • The bottom screw is 7.6mm
  5. Sony VAIO VGN-FW 590 Keyboard Replacement: 5 단계, 이미지 1/1
    • Open the computer
  6. Sony VAIO VGN-FW 590 Keyboard Replacement: 6 단계, 이미지 1/1
    • Remove the audio panel above the keyboard.
    • Lift one corner gently with a flat tool or fingernail.
    • Pull the rest of the panel gently out by hand.
  7. Sony VAIO VGN-FW 590 Keyboard Replacement: 7 단계, 이미지 1/1
    • Lift the keyboard gently, starting with one of the top corners.
    • Pull keyboard gently from body of computer to prevent warping or breakage.
    • Caution Do not remove completely.
  8. Sony VAIO VGN-FW 590 Keyboard Replacement: 8 단계, 이미지 1/3 Sony VAIO VGN-FW 590 Keyboard Replacement: 8 단계, 이미지 2/3 Sony VAIO VGN-FW 590 Keyboard Replacement: 8 단계, 이미지 3/3
    • Locate the connector ribbon behind the keyboard.
    • Gently pull the ribbon from the locking device. It may take a few tries.
    • Caution Do not tear the ribbon.
결론
Jennifer Pache
회원 가입일: 10/30/17
304 평판
안내서 3개 작성하였습니다
University of North Texas, Team S1-G3, Boettger Fall 2017 University of North Texas, Team S1-G3, Boettger Fall 2017 회원
UNT-BOETTGER-F17S1G3
3 회원들
안내서 10개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 13
전체 시간: 1,032
