주요 콘텐츠로 건너뛰기
Sony VAIO VPC-EB33FM RAM Replacement
필요한 것
  1. Sony VAIO VPC-EB33FM RAM Replacement, Battery: 1 단계, 이미지 1/2 Sony VAIO VPC-EB33FM RAM Replacement, Battery: 1 단계, 이미지 2/2
    • Power down the laptop by pressing the power button.
    • Turn the laptop onto its backside.
  2. Sony VAIO VPC-EB33FM RAM Replacement: 2 단계, 이미지 1/1
    • To release the battery, hold both the release button and the unlock button at the same time.
  3. Sony VAIO VPC-EB33FM RAM Replacement: 3 단계, 이미지 1/2 Sony VAIO VPC-EB33FM RAM Replacement: 3 단계, 이미지 2/2
    • Remove the battery out from the notch while continuing to hold the release button.
  4. Sony VAIO VPC-EB33FM RAM Replacement, RAM: 4 단계, 이미지 1/3 Sony VAIO VPC-EB33FM RAM Replacement, RAM: 4 단계, 이미지 2/3 Sony VAIO VPC-EB33FM RAM Replacement, RAM: 4 단계, 이미지 3/3
    • Remove the one screw with a Phillips #00 screwdriver.
    • The screw cannot be removed from the RAM casing cover.
  5. Sony VAIO VPC-EB33FM RAM Replacement: 5 단계, 이미지 1/2 Sony VAIO VPC-EB33FM RAM Replacement: 5 단계, 이미지 2/2
    • Pull the two retaining arms away from the center of the RAM chip.
    • The RAM will make a "pop" sound and the RAM stick will rise for ease of handling.
  6. Sony VAIO VPC-EB33FM RAM Replacement: 6 단계, 이미지 1/3 Sony VAIO VPC-EB33FM RAM Replacement: 6 단계, 이미지 2/3 Sony VAIO VPC-EB33FM RAM Replacement: 6 단계, 이미지 3/3
    • Pull the RAM stick out of its socket.
    • To remove the second stick of RAM, repeat steps six and seven.
    • When installing RAM, make sure sticks are firmly in place or the computer will not register them.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Bret Omsberg
회원 가입일: 01/14/13
16 평판
안내서 1개 작성함
Cal Poly, Team 18-39, Regan Winter 2013 Cal Poly, Team 18-39, Regan Winter 2013 회원
CPSU-REGAN-W13S18G39
5 회원들
안내서 15개 작성하였습니다
댓글 한 개
when i press the power button in VAio still black screen with little tick sound,
and one day i just turn it on and leave it for 17 hours and sadnlley it worked but when i tried to restart it it still not working with tick tick tick tick sound !!! any advise !!!?
dorii135 - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 5
30일 전: 8
전체 시간: 4,296
