주요 콘텐츠로 건너뛰기
Sony VAIO VPCEE26FX Battery Replacement
  1. Sony VAIO VPCEE26FX Battery Replacement, Battery: 1 단계, 이미지 1/2 Sony VAIO VPCEE26FX Battery Replacement, Battery: 1 단계, 이미지 2/2
    • Ensure that the laptop is powered off before disconnecting the battery.
    • Flip the laptop over so the underside of the laptop is facing up.
  2. Sony VAIO VPCEE26FX Battery Replacement: 2 단계, 이미지 1/2 Sony VAIO VPCEE26FX Battery Replacement: 2 단계, 이미지 2/2
    • Slide the two tabs towards each other until the battery disconnects slightly from its position.
    • Carefully lift the battery out of its position away from the laptop.
    • The battery is not pictured here, since it is missing from this particular device.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Christopher Hover
회원 가입일: 03/21/19
679 평판
안내서 5개 작성하였습니다
UMass Dartmouth, Team S2-G3, Bailey Spring 2019 UMass Dartmouth, Team S2-G3, Bailey Spring 2019 회원
UMASSD-BAILEY-S19S2G3
3 회원들
안내서 10개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 5
30일 전: 16
전체 시간: 711
