주요 콘텐츠로 건너뛰기
Sony VAIO VPCEE26FX Keyboard Replacement
필요한 것
  1. Sony VAIO VPCEE26FX Keyboard Replacement, Battery: 1 단계, 이미지 1/2 Sony VAIO VPCEE26FX Keyboard Replacement, Battery: 1 단계, 이미지 2/2
    • Ensure that the laptop is powered off before disconnecting the battery.
    • Flip the laptop over so the underside of the laptop is facing up.
  2. Sony VAIO VPCEE26FX Keyboard Replacement: 2 단계, 이미지 1/2 Sony VAIO VPCEE26FX Keyboard Replacement: 2 단계, 이미지 2/2
    • Slide the two tabs towards each other until the battery disconnects slightly from its position.
    • Carefully lift the battery out of its position away from the laptop.
    • The battery is not pictured here, since it is missing from this particular device.
  3. Sony VAIO VPCEE26FX Keyboard Replacement, Keyboard: 3 단계, 이미지 1/2 Sony VAIO VPCEE26FX Keyboard Replacement, Keyboard: 3 단계, 이미지 2/2
    • Flip the laptop back over so it is face up.
    • Open up the laptop.
  4. Sony VAIO VPCEE26FX Keyboard Replacement: 4 단계, 이미지 1/1
    • Using a plastic opening tool, pry along the seam between the keyboard and case to help in separating the two.
    • Continue to lift up gently using the plastic opening tool until the keyboard begins to separate from the case.
  5. Sony VAIO VPCEE26FX Keyboard Replacement: 5 단계, 이미지 1/2 Sony VAIO VPCEE26FX Keyboard Replacement: 5 단계, 이미지 2/2
    • Continue lifting up and moving down starting on the left side of the keyboard moving towards the right side of the computer.
  6. Sony VAIO VPCEE26FX Keyboard Replacement: 6 단계, 이미지 1/2 Sony VAIO VPCEE26FX Keyboard Replacement: 6 단계, 이미지 2/2
    이 단계에 사용된 도구:
    구매
    • Carefully tilt the top of the keyboard towards you ensuring the ribbon cable is not under too much tension.
    • Use a pair of tweezers to help remove the plastic adhesive film covering the adapter/port for the ribbon cable.
  7. Sony VAIO VPCEE26FX Keyboard Replacement: 7 단계, 이미지 1/1
  8. Sony VAIO VPCEE26FX Keyboard Replacement: 8 단계, 이미지 1/1
    • Lift the keyboard up and away from the computer.
결론
Christopher Hover
회원 가입일: 03/21/19
679 평판
안내서 5개 작성하였습니다
UMass Dartmouth, Team S2-G3, Bailey Spring 2019 UMass Dartmouth, Team S2-G3, Bailey Spring 2019 회원
UMASSD-BAILEY-S19S2G3
3 회원들
안내서 10개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 4
30일 전: 19
전체 시간: 1,175
