주요 콘텐츠로 건너뛰기
Sony VAIO VPCEE26FX RAM Replacement
필요한 것
  1. Sony VAIO VPCEE26FX RAM Replacement, Battery: 1 단계, 이미지 1/2 Sony VAIO VPCEE26FX RAM Replacement, Battery: 1 단계, 이미지 2/2
    • Ensure that the laptop is powered off before disconnecting the battery.
    • Flip the laptop over so the underside of the laptop is facing up.
  2. Sony VAIO VPCEE26FX RAM Replacement: 2 단계, 이미지 1/2 Sony VAIO VPCEE26FX RAM Replacement: 2 단계, 이미지 2/2
    • Slide the two tabs towards each other until the battery disconnects slightly from its position.
    • Carefully lift the battery out of its position away from the laptop.
    • The battery is not pictured here, since it is missing from this particular device.
  3. Sony VAIO VPCEE26FX RAM Replacement, RAM: 3 단계, 이미지 1/1
    • Using a JIS #0 screwdriver, loosen the captive screw attached to the RAM cover.
    • This screw will not come out all the way, but will remain attached to the cover instead.
  4. Sony VAIO VPCEE26FX RAM Replacement: 4 단계, 이미지 1/1
    • Remove the cover which will reveal the two RAM sticks.
  5. Sony VAIO VPCEE26FX RAM Replacement: 5 단계, 이미지 1/3 Sony VAIO VPCEE26FX RAM Replacement: 5 단계, 이미지 2/3 Sony VAIO VPCEE26FX RAM Replacement: 5 단계, 이미지 3/3
    • Push the two tabs holding the RAM sticks in place, away from each other.
    • The first RAM stick will pop up out of place. Remove it away from its position.
  6. Sony VAIO VPCEE26FX RAM Replacement: 6 단계, 이미지 1/3 Sony VAIO VPCEE26FX RAM Replacement: 6 단계, 이미지 2/3 Sony VAIO VPCEE26FX RAM Replacement: 6 단계, 이미지 3/3
    • Push the two tabs holding the second RAM stick in, away from each other.
    • The second RAM stick will pop up out of place. Remove it away from its position.
결론
Christopher Hover
회원 가입일: 03/21/19
679 평판
안내서 5개 작성하였습니다
UMass Dartmouth, Team S2-G3, Bailey Spring 2019 UMass Dartmouth, Team S2-G3, Bailey Spring 2019 회원
UMASSD-BAILEY-S19S2G3
3 회원들
안내서 10개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 3
7일 전: 6
30일 전: 22
전체 시간: 1,397
