주요 콘텐츠로 건너뛰기
Sony VAIO VPCF 132FX Bottom Case Replacement
필요한 것
  1. Sony VAIO VPCF 132FX Bottom Case Replacement, Battery: 1 단계, 이미지 1/1
    • Remove all wires then flip the laptop
  2. Sony VAIO VPCF 132FX Bottom Case Replacement: 2 단계, 이미지 1/2 Sony VAIO VPCF 132FX Bottom Case Replacement: 2 단계, 이미지 2/2
    • Remove the battery
  3. Sony VAIO VPCF 132FX Bottom Case Replacement, RAM: 3 단계, 이미지 1/3 Sony VAIO VPCF 132FX Bottom Case Replacement, RAM: 3 단계, 이미지 2/3 Sony VAIO VPCF 132FX Bottom Case Replacement, RAM: 3 단계, 이미지 3/3
    • Flip the Laptop, and unscrew the RAM cover.
  4. Sony VAIO VPCF 132FX Bottom Case Replacement: 4 단계, 이미지 1/2 Sony VAIO VPCF 132FX Bottom Case Replacement: 4 단계, 이미지 2/2
    • Unlock the RAM by pulling the locks outward.
    • You'll know if its unlocked if it flips up in 45 degrees.
  5. Sony VAIO VPCF 132FX Bottom Case Replacement: 5 단계, 이미지 1/2 Sony VAIO VPCF 132FX Bottom Case Replacement: 5 단계, 이미지 2/2
    • Pull the outer RAM. Repeat Step 4 and 5 for the other RAM.
    • When returning, put the RAM back in at 45 degree angle, NOT 90 degree angle.
  6. Sony VAIO VPCF 132FX Bottom Case Replacement, CD/DVD Drive: 6 단계, 이미지 1/2 Sony VAIO VPCF 132FX Bottom Case Replacement, CD/DVD Drive: 6 단계, 이미지 2/2
    • Remove the 2 screws holding the CD/DVD Drive.
  7. Sony VAIO VPCF 132FX Bottom Case Replacement: 7 단계, 이미지 1/2 Sony VAIO VPCF 132FX Bottom Case Replacement: 7 단계, 이미지 2/2
    • Slide the CD/DVD Drive out.
  8. Sony VAIO VPCF 132FX Bottom Case Replacement, Hard Disk Drive / Solid State Drive: 8 단계, 이미지 1/3 Sony VAIO VPCF 132FX Bottom Case Replacement, Hard Disk Drive / Solid State Drive: 8 단계, 이미지 2/3 Sony VAIO VPCF 132FX Bottom Case Replacement, Hard Disk Drive / Solid State Drive: 8 단계, 이미지 3/3
    • Remove the screws.
    • Slide the HD cover outward then lift.
  9. Sony VAIO VPCF 132FX Bottom Case Replacement: 9 단계, 이미지 1/3 Sony VAIO VPCF 132FX Bottom Case Replacement: 9 단계, 이미지 2/3 Sony VAIO VPCF 132FX Bottom Case Replacement: 9 단계, 이미지 3/3
    • Slide to where the arrow points to unlock the HD.
    • Hold it at the side. Never touch the circuits.
  10. Sony VAIO VPCF 132FX Bottom Case Replacement: 10 단계, 이미지 1/1
    • Remove the 4 screws at the side and remove the HDD/SSD
  11. Sony VAIO VPCF 132FX Bottom Case Replacement, Bottom Case: 11 단계, 이미지 1/2 Sony VAIO VPCF 132FX Bottom Case Replacement, Bottom Case: 11 단계, 이미지 2/2
    • Remove all the other screws.
    • Dont forget the 3 screws after you remove the CD/DVD Drive.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Marjorie
회원 가입일: 12/23/13
2,273 평판
안내서 11개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 1
전체 시간: 861
