주요 콘텐츠로 건너뛰기
Sony VAIO VPCF 132FX Media Board Replacement
필요한 것
  1. Sony VAIO VPCF 132FX Media Board Replacement, Battery: 1 단계, 이미지 1/1
    • Remove all wires then flip the laptop
  2. Sony VAIO VPCF 132FX Media Board Replacement: 2 단계, 이미지 1/2 Sony VAIO VPCF 132FX Media Board Replacement: 2 단계, 이미지 2/2
    • Remove the battery
  3. Sony VAIO VPCF 132FX Media Board Replacement, Media Board: 3 단계, 이미지 1/1
    • Remove the screws and flip it back.
  4. Sony VAIO VPCF 132FX Media Board Replacement: 4 단계, 이미지 1/3 Sony VAIO VPCF 132FX Media Board Replacement: 4 단계, 이미지 2/3 Sony VAIO VPCF 132FX Media Board Replacement: 4 단계, 이미지 3/3
    • Lift the screen and slide your nail or any flat plastic to the side of the cover to unclip it.
    • Slide from the sides towards the center.
  5. Sony VAIO VPCF 132FX Media Board Replacement: 5 단계, 이미지 1/1
    • Gently remove the wire of the Power Button.
  6. Sony VAIO VPCF 132FX Media Board Replacement: 6 단계, 이미지 1/3 Sony VAIO VPCF 132FX Media Board Replacement: 6 단계, 이미지 2/3 Sony VAIO VPCF 132FX Media Board Replacement: 6 단계, 이미지 3/3
    • Unlock the Lock.
    • Unscrew the 3 Flat screws and remove the Media Board.
    • You may skip this step if replacing the Power Button.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Marjorie
회원 가입일: 12/23/13
2,273 평판
안내서 11개 작성하였습니다
댓글 한 개
What are the functions of the media board? My vaio vgn-fw170j won't power up (no LEDS on the power switch, or anywhere else, no fan, nothing). Verified that MoBo has 19.5 VDC on the board. Replaced MoBo and CPU, still no response. Since power button plugs into Media Board, figured it might be failed - any idea if this could be the cause?
course2kid - 답글
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 3
30일 전: 4
전체 시간: 1,382
