주요 콘텐츠로 건너뛰기
Sony Vaio Duo 11 SSD Replacement
필요한 것
  1. Sony Vaio Duo 11 SSD Replacement, SSD: 1 단계, 이미지 1개 중 1개
    • Make a system backup!
  2. Sony Vaio Duo 11 SSD Replacement: 2 단계, 이미지 2개 중 1개 Sony Vaio Duo 11 SSD Replacement: 2 단계, 이미지 2개 중 2개
    • Using a spudger, remove the rubber screw covers.
    • Gently remove the speaker covers.
  3. Sony Vaio Duo 11 SSD Replacement: 3 단계, 이미지 1개 중 1개
    • Use a sharp tool to lift up the laptop's cover
  4. Sony Vaio Duo 11 SSD Replacement: 4 단계, 이미지 1개 중 1개
    • Remove cover
  5. Sony Vaio Duo 11 SSD Replacement: 5 단계, 이미지 1개 중 1개
    • Remove all the screws. (Attention: these screws are different! Save them.)
  6. Sony Vaio Duo 11 SSD Replacement: 6 단계, 이미지 2개 중 1개 Sony Vaio Duo 11 SSD Replacement: 6 단계, 이미지 2개 중 2개
    • Remove the cover carefully. One side is attached with a short, flat, white cable. (Attention: Don't detach the white cable.)
    • Remove the screws (circled in red) and remove the battery.
    • When reassembling : Remember to hide the piece of plastic beside the battery (circled in the second picture) behind the plastic. Otherwise you will not be able to press the right mouse button.
  7. Sony Vaio Duo 11 SSD Replacement: 7 단계, 이미지 1개 중 1개
    • Detach flat cable. To do so, you have to lift the black plastic bar, then release the orange ribbon.
  8. Sony Vaio Duo 11 SSD Replacement: 8 단계, 이미지 1개 중 1개
    • Remove these screws to make it easier to remove the SSD.
  9. Sony Vaio Duo 11 SSD Replacement: 9 단계, 이미지 1개 중 1개
    • The remove of the ssd
    • Remove the SSD (gently)
    • Replace the SSD ( it is a mSATA SSD )
    • Put back the screws and close the unit
결론
다른 26명이 해당 안내서를 완성하였습니다.
작성자
11다른 기여자 명과 함께
Zero
회원 가입일: 01/08/13
880 평판
안내서 1개를 작성함
14가이드 댓글
Mind BLOWING!!!!!!!!!!!!! Job, Bro..... It Helped me a Lot.....
Anwar - 답글
1TB ssd here I come!!!!
jamice4u - 답글
It worked! Can't believe it. I exchanged my 128GB one with a Crucial 500 GB one. Used the Acronis True Image that came with the new SSD. Still getting used to having so much free space :D
scorpiotide - 답글
Hi, I tried to upgrade to a 256GB SSD using shadowprotect and EaseUS to restore the image, but the drive would never boot. The SSD was not the problem as it worked fine when installing Windows from scratch. Did you simply restore a disk image with Acronis?
gps -
Thanks for this tutorial. I typically avoid working on my laptops and gadgets due to overwhelming hidden gotchas. This made swapping out my broken hard drive quick and painless. Thanks again!
Nathan Price - 답글
댓글 쓰기
조회 통계:
지난 24시간: 3
지난 7일: 25
지난 30일: 86
전체 시간: 42,396
