주요 콘텐츠로 건너뛰기
Sony Vaio Duo 11 SSD Replacement
필요한 것
  1. Sony Vaio Duo 11 SSD Replacement, SSD: 1 단계, 이미지 1/1
    • Make a system backup!
  2. Sony Vaio Duo 11 SSD Replacement: 2 단계, 이미지 1/2 Sony Vaio Duo 11 SSD Replacement: 2 단계, 이미지 2/2
    • Using a spudger, remove the rubber screw covers.
    • Gently remove the speaker covers.
    With they way the speaker covers are taped on, I wasn’t able to remove without bending/damaging the covers.
    Michael - 답글
  3. Sony Vaio Duo 11 SSD Replacement: 3 단계, 이미지 1/1
    • Use a sharp tool to lift up the laptop's cover
  4. Sony Vaio Duo 11 SSD Replacement: 4 단계, 이미지 1/1
    • Remove cover
  5. Sony Vaio Duo 11 SSD Replacement: 5 단계, 이미지 1/1
    • Remove all the screws. (Attention: these screws are different! Save them.)
  6. Sony Vaio Duo 11 SSD Replacement: 6 단계, 이미지 1/2 Sony Vaio Duo 11 SSD Replacement: 6 단계, 이미지 2/2
    • Remove the cover carefully. One side is attached with a short, flat, white cable. (Attention: Don't detach the white cable.)
    • Remove the screws (circled in red) and remove the battery.
    • When reassembling : Remember to hide the piece of plastic beside the battery (circled in the second picture) behind the plastic. Otherwise you will not be able to press the right mouse button.
  7. Sony Vaio Duo 11 SSD Replacement: 7 단계, 이미지 1/1
    • Detach flat cable. To do so, you have to lift the black plastic bar, then release the orange ribbon.
  8. Sony Vaio Duo 11 SSD Replacement: 8 단계, 이미지 1/1
    • Remove these screws to make it easier to remove the SSD.
    On mine, model #Svd11223cxb, There were 2 screws to remove (The two under the fan), The third (beside batter connector) was already removed in the base/cover disassembly.
    Michael - 답글
  9. Sony Vaio Duo 11 SSD Replacement: 9 단계, 이미지 1/1
    • The remove of the ssd
    • Remove the SSD (gently)
    • Replace the SSD ( it is a mSATA SSD )
    • Put back the screws and close the unit
결론
다른 25명이 해당 안내서를 완성하였습니다.
Zero
회원 가입일: 01/08/13
856 평판
안내서 1개 작성함
댓글 12개
Mind BLOWING!!!!!!!!!!!!! Job, Bro..... It Helped me a Lot.....
Anwar - 답글
1TB ssd here I come!!!!
jamice4u - 답글
It worked! Can't believe it. I exchanged my 128GB one with a Crucial 500 GB one. Used the Acronis True Image that came with the new SSD. Still getting used to having so much free space :D
scorpiotide - 답글
Hi, I tried to upgrade to a 256GB SSD using shadowprotect and EaseUS to restore the image, but the drive would never boot. The SSD was not the problem as it worked fine when installing Windows from scratch. Did you simply restore a disk image with Acronis?
gps -
Thanks for this tutorial. I typically avoid working on my laptops and gadgets due to overwhelming hidden gotchas. This made swapping out my broken hard drive quick and painless. Thanks again!
Nathan Price - 답글
Thanks so much!! It worked for me though somehow my internal speakers and headphones are gone (After re-installing custom windows 8.1) Could the yellow flexible flat cable be in any way connected to the sound card? I would appreciate any help
Libanga Ochola - 답글
Try this: Go to Control Panel>System and Security>System and to the left, click on Advanced System Settings. Worked for me:
https://community.sony.com/t5/VAIO-Windo...
tenebro -
J'ai un vaio duo 11 à vendre
Intel Core i5-3337U 1.8GHz / 8Go de Ram / Windows 10 Argent En plus de l'ordinateur, une carte mémoire 256Go et une pochette de transport en cuir.
Le prix neuf de l'ordinateur était 1600€
https://www.amazon.fr/Sony-SVD1121P2EB-F...
filoucrx - 답글
What's the implications with the Short flat cable?
Welty - 답글
Hi, where can I buy a replacement SSD to suit my SONY VAIO SVD112A1SW?
Fabian Bettiol - 답글
Hi, what do you do with old SSD?
Marek Malý - 답글
I understand that this model discontinued
Is they any source to get a new battery
Alaa - 답글
댓글 쓰기
조회 통계:
24 시간 전: 3
7일 전: 6
30일 전: 47
전체 시간: 41,127
