주요 콘텐츠로 건너뛰기
Sony Vaio Fit 13A Battery Replacement
필요한 것
  1. Sony Vaio Fit 13A Battery Replacement, Back Cover: 1 단계, 이미지 1/2 Sony Vaio Fit 13A Battery Replacement, Back Cover: 1 단계, 이미지 2/2
    • Starting with the laptop top-down, locate and remove the twelve 1mm Phillips #0 screws securing the back cover to the main body of the computer.
  2. Sony Vaio Fit 13A Battery Replacement: 2 단계, 이미지 1/2 Sony Vaio Fit 13A Battery Replacement: 2 단계, 이미지 2/2
    • Use the Plastic Opening Tools or Metal Spudger to carefully loosen back cover from the body of the computer.
    • Be sure to avoid headphone jack when removing back cover by lifting cover away from computer and up.
  3. Sony Vaio Fit 13A Battery Replacement: 3 단계, 이미지 1/1
    • Lift off back cover to access inner components of computer.
  4. Sony Vaio Fit 13A Battery Replacement, Battery: 4 단계, 이미지 1/2 Sony Vaio Fit 13A Battery Replacement, Battery: 4 단계, 이미지 2/2
    • Locate and remove the ten 1mm Phillips #0 screws that are securing the battery in place.
  5. Sony Vaio Fit 13A Battery Replacement: 5 단계, 이미지 1/2 Sony Vaio Fit 13A Battery Replacement: 5 단계, 이미지 2/2
    • Remove the battery with the Plastic Opening Tool by placing the tool between the battery and the computer and cautiously prying it out.
결론
다른 3명이 해당 안내서를 완성하였습니다.
Alex Prange
회원 가입일: 01/08/15
527 평판
안내서 3개 작성하였습니다
Cal Poly, Team 21-19, Maness Winter 2015 Cal Poly, Team 21-19, Maness Winter 2015 회원
CPSU-MANESS-W15S21G19
4 회원들
안내서 12개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 21
전체 시간: 7,827
