주요 콘텐츠로 건너뛰기
Sony Vaio Fit 13A SVF13NA1EL Battery Replacement
필요한 것
  1. Sony Vaio Fit 13A SVF13NA1EL Battery Replacement, Battery: 1 단계, 이미지 1/1
    • Begin by turning the laptop top-down on a flat surface.
    • Use a JIS #1 screwdriver to remove the 4 screws circled in red
    • Use a JIS #0 screwdriver to remove the 8 screws circled in orange
    • Many of these screws are located underneath the rubber pads on the device.
    • Keep track of the locations of the screws removed for ease of reassembly.
  2. Sony Vaio Fit 13A SVF13NA1EL Battery Replacement: 2 단계, 이미지 1/1
    • Use a spudger to carefully remove the back cover of the laptop.
    • Be careful when lifting around the ports and headphone jack to avoid causing damage to these components.
  3. Sony Vaio Fit 13A SVF13NA1EL Battery Replacement: 3 단계, 이미지 1/2 Sony Vaio Fit 13A SVF13NA1EL Battery Replacement: 3 단계, 이미지 2/2
    • Lift up back cover to access internal components of the laptop.
  4. Sony Vaio Fit 13A SVF13NA1EL Battery Replacement: 4 단계, 이미지 1/1
    • Remove the screws in the circled areas using the J0 Screwdriver to release the battery.
  5. Sony Vaio Fit 13A SVF13NA1EL Battery Replacement: 5 단계, 이미지 1/2 Sony Vaio Fit 13A SVF13NA1EL Battery Replacement: 5 단계, 이미지 2/2
    • Lift the battery from the laptop to remove.
    • Replace if necessary.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Olivia
회원 가입일: 09/08/17
605 평판
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 5
7일 전: 22
30일 전: 81
전체 시간: 4,059
