주요 콘텐츠로 건너뛰기
Sony Vaio Fit 13A SVF13NA1EL Screen Connector
필요한 것
  1. Sony Vaio Fit 13A SVF13NA1EL Screen Connector, Sony Vaio Fit 13A SVF13NA1EL Screen Connector: 1 단계, 이미지 1개 중 1개
    • Flip over the screen
    • Remove all 8 screws as shown circled in the image using a Phillips #0
  2. Sony Vaio Fit 13A SVF13NA1EL Screen Connector: 2 단계, 이미지 3개 중 1개 Sony Vaio Fit 13A SVF13NA1EL Screen Connector: 2 단계, 이미지 3개 중 2개 Sony Vaio Fit 13A SVF13NA1EL Screen Connector: 2 단계, 이미지 3개 중 3개
    • Flip the screen back over.
    • Use a plastic spudger to remove the top section of the cover.
  3. Sony Vaio Fit 13A SVF13NA1EL Screen Connector: 3 단계, 이미지 1개 중 1개
    • Unplug the screen connecter from the back of the screen.
  4. Sony Vaio Fit 13A SVF13NA1EL Screen Connector: 4 단계, 이미지 1개 중 1개
    • Disconnect the ribbon wire from the LCD connector by gently pulling it.
  5. Sony Vaio Fit 13A SVF13NA1EL Screen Connector: 5 단계, 이미지 2개 중 1개 Sony Vaio Fit 13A SVF13NA1EL Screen Connector: 5 단계, 이미지 2개 중 2개
    • Gently raise the metal framework of the laptop to reveal the remaining portion of the screen connector.
    • Follow the ribbon wiring to where it connects to the screen.
    • Carefully pull the wiring to disconnect and click it back in place to reconnect.
결론
다른 4명이 해당 안내서를 완성하였습니다.
작성자
4다른 기여자 명과 함께
Olivia
회원 가입일: 09/08/17
605 평판
안내서 5개를 작성함
댓글 5개
Where to buy or to repair screen connector for Vaio Fit SVF13N13
Adham Ahmed - 답글
Where to replace the keyboard of Vaio SVF13N2
Arturo Dameno - 답글
Where i buy flexi
msobirin48 - 답글
The procedure is nicely explained
Is there an option to replace the LCD flet cable ... ?
It is complicated but we found a defect on the flet cable.
servis računara - 답글
I found some spareparts over the sony website. With all data from you laptop you can find them here https://uk.eetgroup.com/Guide/m/Sony-VAI...
Lukas Lutz - 답글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 9
지난 30일: 27
전체 시간: 4,414
