주요 콘텐츠로 건너뛰기
Sony Vaio Fit 13A Wireless Card Replacement
필요한 것
  1. Sony Vaio Fit 13A Wireless Card Replacement, Back Cover: 1 단계, 이미지 1/2 Sony Vaio Fit 13A Wireless Card Replacement, Back Cover: 1 단계, 이미지 2/2
    • Starting with the laptop top-down, locate and remove the twelve 1mm Phillips #0 screws securing the back cover to the main body of the computer.
  2. Sony Vaio Fit 13A Wireless Card Replacement: 2 단계, 이미지 1/2 Sony Vaio Fit 13A Wireless Card Replacement: 2 단계, 이미지 2/2
    • Use the Plastic Opening Tools or Metal Spudger to carefully loosen back cover from the body of the computer.
    • Be sure to avoid headphone jack when removing back cover by lifting cover away from computer and up.
  3. Sony Vaio Fit 13A Wireless Card Replacement: 3 단계, 이미지 1/1
    • Lift off back cover to access inner components of computer.
  4. Sony Vaio Fit 13A Wireless Card Replacement, Wireless Card: 4 단계, 이미지 1/3 Sony Vaio Fit 13A Wireless Card Replacement, Wireless Card: 4 단계, 이미지 2/3 Sony Vaio Fit 13A Wireless Card Replacement, Wireless Card: 4 단계, 이미지 3/3
    이 단계에 사용된 도구:
    구매
    • Use a pair of tweezers to gently disconnect the two antenna cables.
  5. Sony Vaio Fit 13A Wireless Card Replacement: 5 단계, 이미지 1/2 Sony Vaio Fit 13A Wireless Card Replacement: 5 단계, 이미지 2/2
    • Locate and remove the single 1mm Phillips #0 screw that is securing the wireless card to the motherboard.
  6. Sony Vaio Fit 13A Wireless Card Replacement: 6 단계, 이미지 1/2 Sony Vaio Fit 13A Wireless Card Replacement: 6 단계, 이미지 2/2
    • Gently grasp wireless card with two fingers and pull away from motherboard to the left.
    • Do not pull the wireless card up when removing it. This could snap the connections.
결론
Alex Prange
회원 가입일: 01/08/15
527 평판
안내서 3개 작성하였습니다
Cal Poly, Team 21-19, Maness Winter 2015 Cal Poly, Team 21-19, Maness Winter 2015 회원
CPSU-MANESS-W15S21G19
4 회원들
안내서 12개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 8
전체 시간: 1,846
