주요 콘텐츠로 건너뛰기
Sony Vaio Fit SVF13N1ASNS Display Replacement
필요한 것
  1. Sony Vaio Fit SVF13N1ASNS Display Replacement, Battery: 1 단계, 이미지 1/2 Sony Vaio Fit SVF13N1ASNS Display Replacement, Battery: 1 단계, 이미지 2/2
    • Remove the following ten screws from the bottom case of the laptop:
    • Two 6.5mm Phillips #00 Phillips screws.
    • Four 8.95mm Phillips #00 screws.
    • Four 6.25mm Phillips #00 screws.
    • The screws may be hidden underneath a rubber foot that can be removed with a spudger.
  2. Sony Vaio Fit SVF13N1ASNS Display Replacement: 2 단계, 이미지 1/2 Sony Vaio Fit SVF13N1ASNS Display Replacement: 2 단계, 이미지 2/2
    • Use a plastic opening tool to separate the bottom cover from the laptop.
    • Lift the lower cover and pull away from the laptop.
  3. Sony Vaio Fit SVF13N1ASNS Display Replacement: 3 단계, 이미지 1/3 Sony Vaio Fit SVF13N1ASNS Display Replacement: 3 단계, 이미지 2/3 Sony Vaio Fit SVF13N1ASNS Display Replacement: 3 단계, 이미지 3/3
    • Remove the eight Phillips #00 screws from the battery:
    • Six 4.65mm screws.
    • Two 4.65mm screws.
  4. Sony Vaio Fit SVF13N1ASNS Display Replacement: 4 단계, 이미지 1/1
    • Lift the battery up and pull it out of the laptop.
  5. Sony Vaio Fit SVF13N1ASNS Display Replacement, Display: 5 단계, 이미지 1/1
    • Open the laptop and rotate the screen to the back side.
    • Remove the eight 2.85mm Phillips #00 screws from the back of the screen.
  6. Sony Vaio Fit SVF13N1ASNS Display Replacement: 6 단계, 이미지 1/2 Sony Vaio Fit SVF13N1ASNS Display Replacement: 6 단계, 이미지 2/2
    • Rotate the screen back and close the laptop.
    • Use a plastic opening tool to carefully pry up the back plastic case.
    • Remove the back plastic case by sliding it down and pulling upwards.
  7. Sony Vaio Fit SVF13N1ASNS Display Replacement: 7 단계, 이미지 1/2 Sony Vaio Fit SVF13N1ASNS Display Replacement: 7 단계, 이미지 2/2
    • Remove the thirteen 2.85mm Phillips #00 screws from the screen.
  8. Sony Vaio Fit SVF13N1ASNS Display Replacement: 8 단계, 이미지 1/3 Sony Vaio Fit SVF13N1ASNS Display Replacement: 8 단계, 이미지 2/3 Sony Vaio Fit SVF13N1ASNS Display Replacement: 8 단계, 이미지 3/3
    • Use a spudger to lift up the black latch on the ZIF connector.
    • Pull the display ribbon cable out of the ZIF connector.
  9. Sony Vaio Fit SVF13N1ASNS Display Replacement: 9 단계, 이미지 1/3 Sony Vaio Fit SVF13N1ASNS Display Replacement: 9 단계, 이미지 2/3 Sony Vaio Fit SVF13N1ASNS Display Replacement: 9 단계, 이미지 3/3
    • Remove the display cable peeling up the tape.
    • The display cable locking mechanism is attached to the tape.
  10. Sony Vaio Fit SVF13N1ASNS Display Replacement: 10 단계, 이미지 1/1
    • Remove the display.
결론
다른 3명이 해당 안내서를 완성하였습니다.
Althea McDavid
회원 가입일: 02/14/18
857 평판
안내서 6개 작성하였습니다
USF Tampa, Team S2-G4, Nance Spring 2018 USF Tampa, Team S2-G4, Nance Spring 2018 회원
USFT-NANCE-S18S2G4
4 회원들
안내서 12개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 16
전체 시간: 2,527
