주요 콘텐츠로 건너뛰기
Sony Vaio Fit SVF14A190X Battery Replacement
필요한 것
  1. Sony Vaio Fit SVF14A190X  Battery Replacement, Battery Replacement: 1 단계, 이미지 1/1
    • Make sure the battery is drained or the computer is turned off.
    • Use the Phillips head screw driver to remove the eleven 6 mm screws.
    • Use the Phillips head screw driver to remove the one 4 mm screw securing the CD drive.
  2. Sony Vaio Fit SVF14A190X  Battery Replacement: 2 단계, 이미지 1/3 Sony Vaio Fit SVF14A190X  Battery Replacement: 2 단계, 이미지 2/3 Sony Vaio Fit SVF14A190X  Battery Replacement: 2 단계, 이미지 3/3
    • Insert the plastic opening tool into the slit of the CD drive.
    • Then pull it outwards.
    • Grab the CD drive with your hand.
    • Take the CD drive all the way out.
  3. Sony Vaio Fit SVF14A190X  Battery Replacement: 3 단계, 이미지 1/3 Sony Vaio Fit SVF14A190X  Battery Replacement: 3 단계, 이미지 2/3 Sony Vaio Fit SVF14A190X  Battery Replacement: 3 단계, 이미지 3/3
    • Insert the plastic opening tool into the slit between the back cover and the rest of the computer.
    • Move the plastic opening tool around all sides of the device.
    • Peel off the back cover.
  4. Sony Vaio Fit SVF14A190X  Battery Replacement: 4 단계, 이미지 1/2 Sony Vaio Fit SVF14A190X  Battery Replacement: 4 단계, 이미지 2/2
    • Use the Phillips head screw driver to remove the four 7 mm screws.
    • Lift the battery out with your hand.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Randal Crosby
회원 가입일: 02/13/18
187 평판
안내서 1개 작성함
USF Tampa, Team S11-G3, Cheng Spring 2018 USF Tampa, Team S11-G3, Cheng Spring 2018 회원
USFT-CHENG-S18S11G3
4 회원들
안내서 11개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 3
30일 전: 20
전체 시간: 1,852
