소개
This is an easy to follow, step by step guide to help aid in the replacement of a fan for the Sony Vaio Fit SVF14A190X. The fan helps keep your device at cool operating temperatures to prevent overheating.
  1. Make sure the battery is drained or the computer is turned off.
    • Make sure the battery is drained or the computer is turned off.
    • Use the Phillips head screw driver to remove the eleven 6 mm screws.
    • Use the Phillips head screw driver to remove the one 4 mm screw securing the CD drive.
  2. Insert the plastic opening tool into the slit of the  CD drive. Then pull it outwards. Grab the CD drive with your hand.
    • Insert the plastic opening tool into the slit of the CD drive.
    • Then pull it outwards.
    • Grab the CD drive with your hand.
    • Take the CD drive all the way out.
  3. Insert the plastic opening tool into the slit between the back cover and the rest of the computer. Move the plastic opening tool around all sides of the device. Peel off the back cover.
    • Insert the plastic opening tool into the slit between the back cover and the rest of the computer.
    • Move the plastic opening tool around all sides of the device.
    • Peel off the back cover.
  4. 맥북 배터리 수리 키트
    기본 가격은 $69.99
    Buy Now
    맥북 배터리 수리 키트
    기본 가격은 $69.99
    Buy Now
  5. Use the Phillips head screw driver to remove the four 7 mm screws. Lift  the battery out with your hand.
    • Use the Phillips head screw driver to remove the four 7 mm screws.
    • Lift the battery out with your hand.
  6. Use the Phillips head screw driver to remove the two 5 mm screws on the fan.
    • Use the Phillips head screw driver to remove the two 5 mm screws on the fan.
    • Loosen the four screws with the Phillips head screw driver on the copper cooling component. These screws will not come all of the way out.
  7. Gently grab the base of the fan wire connection. Pull the base of the wire connection from the motherboard to disconnect the wires. Pull the base of the wire connection from the motherboard to disconnect the wires.
    • Gently grab the base of the fan wire connection.
    • Pull the base of the wire connection from the motherboard to disconnect the wires.
  8. Once the prior two steps have been completed, obtain the plastic opening tool. Gently place the plastic opening tool underneath the fan and separate the fan from the device by sliding the tool along the bottom of the fan. Once separated, you can now lift the fan out by hand.
    • Once the prior two steps have been completed, obtain the plastic opening tool.
    • Gently place the plastic opening tool underneath the fan and separate the fan from the device by sliding the tool along the bottom of the fan.
    • Once separated, you can now lift the fan out by hand.
결론
Bryan J. Hartman
회원 가입일: 2018년 02월 13일
231 평판
안내서 2개 작성하였습니다
USF Tampa, Team S11-G3, Cheng Spring 2018 USF Tampa, Team S11-G3, Cheng Spring 2018 회원
USFT-CHENG-S18S11G3
4 회원들
안내서 5개 작성하였습니다
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 1
지난 30일: 9
전체 시간: 156
