주요 콘텐츠로 건너뛰기
소개
Unlike many other laptops, the Sony Vaio Fit SVF15N26CXB has its battery within the laptop and thus is not as easy to remove as pulling it out of the back of the computer. This guide will show you how to properly remove the battery. Be sure to use the static wrist strap (shown in the guide) as a precautionary measure and recycle the battery. Also, use the magnetic project mat to keep your screws organized.
  1. Remove the following ten screws from the bottom case of the laptop: Two 6.5mm Phillips #00 Phillips screws.
    • Remove the following ten screws from the bottom case of the laptop:
    • Two 6.5mm Phillips #00 Phillips screws.
    • Four 8.95mm Phillips #00 screws.
    • Four 6.25mm Phillips #00 screws.
    • The screws may be hidden underneath a rubber foot that can be removed with a spudger.
  2. Use a plastic opening tool to separate the bottom cover from the laptop. Lift the lower cover and pull away from the laptop.
    • Use a plastic opening tool to separate the bottom cover from the laptop.
    • Lift the lower cover and pull away from the laptop.
  3. Remove the eight Phillips #00 screws from the battery: Six 4.65mm screws. Two 4.65mm screws.
    • Remove the eight Phillips #00 screws from the battery:
    • Six 4.65mm screws.
    • Two 4.65mm screws.
  4. Lift the battery up and pull it out of the laptop.
    • Lift the battery up and pull it out of the laptop.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Althea McDavid
회원 가입일: 2018년 02월 14일
812 평판
안내서 6개 작성하였습니다
USF Tampa, Team S2-G4, Nance Spring 2018 USF Tampa, Team S2-G4, Nance Spring 2018 회원
USFT-NANCE-S18S2G4
4 회원들
안내서 6개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 7
30일 전: 42
전체 시간: 1,802
