이 버전에는 잘못된 편집 사항이 있을 수 있습니다. 최신 확인된 스냅샷으로 전환하십시오.
필요한 것
이 단계는 번역되지 않았습니다. 번역을 도와주십시오
Remove the following ten screws from the bottom case of the laptop:
Two 6.5mm Phillips #00 Phillips screws.
Four 8.95mm Phillips #00 screws.
Four 6.25mm Phillips #00 screws.
Use a plastic opening tool to separate the bottom cover from the laptop.
Lift the lower cover and pull away from the laptop.
Remove the eight Phillips #00 screws from the battery:
Six 4.65mm screws.
Two 4.65mm screws.
Open the laptop and rotate the screen to the back side.
Remove the eight 2.85mm Phillips #00 screws from the back of the screen.
Rotate the screen back and close the laptop.
Use a plastic opening tool to carefully pry up the back plastic case.
Remove the back plastic case by sliding it down and pulling upwards.
Use a spudger to lift up the black latch on the ZIF connector.
Pull the display ribbon cable out of the ZIF connector.
다른 3명이 해당 안내서를 완성하였습니다.
