주요 콘텐츠로 건너뛰기
Sony Vaio Fit SVF15N26CXB Fan Replacement
필요한 것
  1. Sony Vaio Fit SVF15N26CXB Fan Replacement, Battery: 1 단계, 이미지 1/2 Sony Vaio Fit SVF15N26CXB Fan Replacement, Battery: 1 단계, 이미지 2/2
    • Remove the following ten screws from the bottom case of the laptop:
    • Two 6.5mm Phillips #00 Phillips screws.
    • Four 8.95mm Phillips #00 screws.
    • Four 6.25mm Phillips #00 screws.
    • The screws may be hidden underneath a rubber foot that can be removed with a spudger.
  2. Sony Vaio Fit SVF15N26CXB Fan Replacement: 2 단계, 이미지 1/2 Sony Vaio Fit SVF15N26CXB Fan Replacement: 2 단계, 이미지 2/2
    • Use a plastic opening tool to separate the bottom cover from the laptop.
    • Lift the lower cover and pull away from the laptop.
  3. Sony Vaio Fit SVF15N26CXB Fan Replacement: 3 단계, 이미지 1/3 Sony Vaio Fit SVF15N26CXB Fan Replacement: 3 단계, 이미지 2/3 Sony Vaio Fit SVF15N26CXB Fan Replacement: 3 단계, 이미지 3/3
    • Remove the eight Phillips #00 screws from the battery:
    • Six 4.65mm screws.
    • Two 4.65mm screws.
  4. Sony Vaio Fit SVF15N26CXB Fan Replacement: 4 단계, 이미지 1/1
    • Lift the battery up and pull it out of the laptop.
  5. Sony Vaio Fit SVF15N26CXB Fan Replacement, Fan: 5 단계, 이미지 1/3 Sony Vaio Fit SVF15N26CXB Fan Replacement, Fan: 5 단계, 이미지 2/3 Sony Vaio Fit SVF15N26CXB Fan Replacement, Fan: 5 단계, 이미지 3/3
    • Remove the four 4.58mm Phillips #00 screws from the cooling system.
    • Unscrew the five Phillips #00 screws from the heatsink.
    • These screws will remain attached to the heatsink.
  6. Sony Vaio Fit SVF15N26CXB Fan Replacement: 6 단계, 이미지 1/2 Sony Vaio Fit SVF15N26CXB Fan Replacement: 6 단계, 이미지 2/2
    • Disconnect the fan from the motherboard.
    • This connector should be pulled upwards, not outwards.
    • Remove the fan unit.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Althea McDavid
회원 가입일: 02/14/18
857 평판
안내서 6개 작성하였습니다
USF Tampa, Team S2-G4, Nance Spring 2018 USF Tampa, Team S2-G4, Nance Spring 2018 회원
USFT-NANCE-S18S2G4
4 회원들
안내서 12개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 12
전체 시간: 769
