소개
There are two speaker components (left and right sides) connected by a wire running under the battery. This guide will show the user how to properly remove the speakers from the Sony Vaio Fit SVF15N26CXB. This may be necessary if there is an issue with sound. Use the static wrist strap (shown in the guide) as a precautionary measure. Use the project mat to keep the screws organized.
도구
부품
지정된 부품이 없습니다.
Remove the following ten screws from the bottom case of the laptop:
Two 6.5mm Phillips #00 Phillips screws.
Four 8.95mm Phillips #00 screws.
Four 6.25mm Phillips #00 screws.
다른 한 분이 해당 안내서를 완성하였습니다.
