주요 콘텐츠로 건너뛰기
Sony Vaio Fit SVF15N26CXB Speaker Replacement
필요한 것
  1. Sony Vaio Fit SVF15N26CXB Speaker Replacement, Battery: 1 단계, 이미지 1/2 Sony Vaio Fit SVF15N26CXB Speaker Replacement, Battery: 1 단계, 이미지 2/2
    • Remove the following ten screws from the bottom case of the laptop:
    • Two 6.5mm Phillips #00 Phillips screws.
    • Four 8.95mm Phillips #00 screws.
    • Four 6.25mm Phillips #00 screws.
    • The screws may be hidden underneath a rubber foot that can be removed with a spudger.
  2. Sony Vaio Fit SVF15N26CXB Speaker Replacement: 2 단계, 이미지 1/2 Sony Vaio Fit SVF15N26CXB Speaker Replacement: 2 단계, 이미지 2/2
    • Use a plastic opening tool to separate the bottom cover from the laptop.
    • Lift the lower cover and pull away from the laptop.
  3. Sony Vaio Fit SVF15N26CXB Speaker Replacement: 3 단계, 이미지 1/3 Sony Vaio Fit SVF15N26CXB Speaker Replacement: 3 단계, 이미지 2/3 Sony Vaio Fit SVF15N26CXB Speaker Replacement: 3 단계, 이미지 3/3
    • Remove the eight Phillips #00 screws from the battery:
    • Six 4.65mm screws.
    • Two 4.65mm screws.
  4. Sony Vaio Fit SVF15N26CXB Speaker Replacement: 4 단계, 이미지 1/1
    • Lift the battery up and pull it out of the laptop.
  5. Sony Vaio Fit SVF15N26CXB Speaker Replacement, Speaker: 5 단계, 이미지 1/3 Sony Vaio Fit SVF15N26CXB Speaker Replacement, Speaker: 5 단계, 이미지 2/3 Sony Vaio Fit SVF15N26CXB Speaker Replacement, Speaker: 5 단계, 이미지 3/3
    • Remove six 5.75mm Phillips #00 screws from the speakers.
  6. Sony Vaio Fit SVF15N26CXB Speaker Replacement: 6 단계, 이미지 1/3 Sony Vaio Fit SVF15N26CXB Speaker Replacement: 6 단계, 이미지 2/3 Sony Vaio Fit SVF15N26CXB Speaker Replacement: 6 단계, 이미지 3/3
    • Use a spudger to flip up the black latch on the four ZIF connectors.
    • Remove the four ribbon cables from the ZIF connectors.
    • Disconnect the speaker from the board.
  7. Sony Vaio Fit SVF15N26CXB Speaker Replacement: 7 단계, 이미지 1/2 Sony Vaio Fit SVF15N26CXB Speaker Replacement: 7 단계, 이미지 2/2
    이 단계에 사용된 도구:
    구매
    • Using tweezers, carefully unwind the speakers' wires from the plastic brackets holding them.
    • Where the wire is stuck under tape, gently pull the tape up until the wire is free.
    • Do not remove the tape.
  8. Sony Vaio Fit SVF15N26CXB Speaker Replacement: 8 단계, 이미지 1/1
    • Remove the speakers by picking the left and right pieces up and lifting them up and out of the computer.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Althea McDavid
회원 가입일: 02/14/18
857 평판
안내서 6개 작성하였습니다
USF Tampa, Team S2-G4, Nance Spring 2018 USF Tampa, Team S2-G4, Nance Spring 2018 회원
USFT-NANCE-S18S2G4
4 회원들
안내서 12개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 5
30일 전: 14
전체 시간: 523
