이 버전에는 잘못된 편집 사항이 있을 수 있습니다. 최신 확인된 스냅샷으로 전환하십시오.
필요한 것
이 단계는 번역되지 않았습니다. 번역을 도와주십시오
Remove the following ten screws from the bottom case of the laptop:
Two 6.5mm Phillips #00 Phillips screws.
Four 8.95mm Phillips #00 screws.
Four 6.25mm Phillips #00 screws.
Use a plastic opening tool to separate the bottom cover from the laptop.
Lift the lower cover and pull away from the laptop.
Remove the eight Phillips #00 screws from the battery:
Six 4.65mm screws.
Two 4.65mm screws.
Use a spudger to flip up the black latch on the four ZIF connectors.
Remove the four ribbon cables from the ZIF connectors.
Disconnect the speaker from the board.
Using tweezers, carefully unwind the speakers' wires from the plastic brackets holding them.
Where the wire is stuck under tape, gently pull the tape up until the wire is free.
Remove the speakers by picking the left and right pieces up and lifting them up and out of the computer.
다른 한 분이 해당 안내서를 완성하였습니다.
