주요 콘텐츠로 건너뛰기
Sony Vaio PCG-161L Hard Drive Replacement
필요한 것
  1. Sony Vaio PCG-161L Hard Drive Replacement, Keyboard: 1 단계, 이미지 1/1
    • Turn your device upside down and remove the 6 10mm screws attaching the back casing to the device using a phillips head screwdriver.
  2. Sony Vaio PCG-161L Hard Drive Replacement: 2 단계, 이미지 1/2 Sony Vaio PCG-161L Hard Drive Replacement: 2 단계, 이미지 2/2
    • Lift up underneath the keyboard using the iFixit opening tool to expose the ribbon wires connecting the keyboard to the motherboard.
  3. Sony Vaio PCG-161L Hard Drive Replacement: 3 단계, 이미지 1/2 Sony Vaio PCG-161L Hard Drive Replacement: 3 단계, 이미지 2/2
    • The two ribbon cables connecting the keyboard to the motherboard are held in using zero insertion force (ZIF) connectors.
    • Use a plastic opening tool or your fingernail to flip up the small retaining flaps, then pull the ribbon cables out of their connectors.
  4. Sony Vaio PCG-161L Hard Drive Replacement, Hard Drive: 4 단계, 이미지 1/1
    • Remove the three 10 mm screws holding the casing to the top of the motherboard using a Phillips screwdriver.
  5. Sony Vaio PCG-161L Hard Drive Replacement: 5 단계, 이미지 1/1
    • Remove the 6 mm screw on the left side of the battery that holds the casing to the device using a phillips head screwdriver.
  6. Sony Vaio PCG-161L Hard Drive Replacement: 6 단계, 이미지 1/1
    • Turn the device upside down and remove the other 6 mm screw holding the casing to the device using a phillips head screwdriver.
  7. Sony Vaio PCG-161L Hard Drive Replacement: 7 단계, 이미지 1/2 Sony Vaio PCG-161L Hard Drive Replacement: 7 단계, 이미지 2/2
    • Remove the top casing by lifting up on the plastic.
    • There are no longer any wires connecting the casing to the motherboard. The casing can be fully removed and put to the side.
  8. Sony Vaio PCG-161L Hard Drive Replacement: 8 단계, 이미지 1/1
    • The ribbon cable covering the hard drive and connecting to the motherboard is held in using zero insertion force (ZIF) connector.
    • Use the tip of a spudger or your fingernail to flip up the small retaining flaps, then pull the ribbon cable out.
  9. Sony Vaio PCG-161L Hard Drive Replacement: 9 단계, 이미지 1/1
    • Remove the four 5 mm screws holding the hard drive to the motherboard.
  10. Sony Vaio PCG-161L Hard Drive Replacement: 10 단계, 이미지 1/1
    • Remove the ribbon cable connecting the motherboard to the hard drive by pulling the female connector off of the pins attached the hard drive.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Roman Alshehri
회원 가입일: 03/08/17
407 평판
안내서 4개 작성하였습니다
UMass Dartmouth, Team S3-G2, Botvin Spring 2017 UMass Dartmouth, Team S3-G2, Botvin Spring 2017 회원
UMASSD-BOTVIN-S17S3G2
3 회원들
안내서 8개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 5
30일 전: 21
전체 시간: 976
