주요 콘텐츠로 건너뛰기
Sony Vaio PCG-161L Keyboard Replacement
필요한 것
  1. Sony Vaio PCG-161L Keyboard Replacement, Keyboard: 1 단계, 이미지 1/1
    • Turn your device upside down and remove the 6 10mm screws attaching the back casing to the device using a phillips head screwdriver.
  2. Sony Vaio PCG-161L Keyboard Replacement: 2 단계, 이미지 1/2 Sony Vaio PCG-161L Keyboard Replacement: 2 단계, 이미지 2/2
    • Lift up underneath the keyboard using the iFixit opening tool to expose the ribbon wires connecting the keyboard to the motherboard.
  3. Sony Vaio PCG-161L Keyboard Replacement: 3 단계, 이미지 1/2 Sony Vaio PCG-161L Keyboard Replacement: 3 단계, 이미지 2/2
    • The two ribbon cables connecting the keyboard to the motherboard are held in using zero insertion force (ZIF) connectors.
    • Use a plastic opening tool or your fingernail to flip up the small retaining flaps, then pull the ribbon cables out of their connectors.
결론
Roman Alshehri
회원 가입일: 03/08/17
407 평판
안내서 4개 작성하였습니다
UMass Dartmouth, Team S3-G2, Botvin Spring 2017 UMass Dartmouth, Team S3-G2, Botvin Spring 2017 회원
UMASSD-BOTVIN-S17S3G2
3 회원들
안내서 8개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 4
전체 시간: 295
