소개
Are your speakers in your Sony Vaio PCG-161L no longer working? You can replace them in 30 minutes using this guide.
필요한 것
Turn your device upside down and remove the 6 10mm screws attaching the back casing to the device using a phillips head screwdriver.
Remove the three 10 mm screws holding the casing to the top of the motherboard using a Phillips screwdriver.
거의 끝나갑니다!
결론
다른 한 분이 해당 안내서를 완성하였습니다.
