이 버전에는 잘못된 편집 사항이 있을 수 있습니다. 최신 확인된 스냅샷으로 전환하십시오.
필요한 것
이 단계는 번역되지 않았습니다. 번역을 도와주십시오
Turn your device upside down and remove the 6 10mm screws attaching the back casing to the device using a phillips head screwdriver.
Lift up underneath the keyboard using the iFixit opening tool to expose the ribbon wires connecting the keyboard to the motherboard.
Use a plastic opening tool or your fingernail to flip up the small retaining flaps, then pull the ribbon cables out of their connectors.
Remove the three 10 mm screws holding the casing to the top of the motherboard using a Phillips screwdriver.
Remove the 6 mm Phillips #0 screw on the left side of the battery that holds the casing to the device.
Turn the device upside down and remove the 6 mm Phillips #0 screw holding the casing to the device.
Remove the top casing by lifting up on the plastic exposing the two speakers.
Disconnect the wire from the board by pulling the wire out of the harness.
다른 한 분이 해당 안내서를 완성하였습니다.
