주요 콘텐츠로 건너뛰기
Sony Vaio PCG-31311L Motherboard Replacement
필요한 것
  1. Sony Vaio PCG-31311L Motherboard Replacement, Keyboard: 1 단계, 이미지 1/2 Sony Vaio PCG-31311L Motherboard Replacement, Keyboard: 1 단계, 이미지 2/2
    • Start with device closed, powered off, and upside down.
    • Locate 3 screws on the bottom plate and unscrew
    • These screws do not detach from the bottom plate.
  2. Sony Vaio PCG-31311L Motherboard Replacement: 2 단계, 이미지 1/2 Sony Vaio PCG-31311L Motherboard Replacement: 2 단계, 이미지 2/2
    • Use a plastic opening tool to pry up on the plate and remove from device.
  3. Sony Vaio PCG-31311L Motherboard Replacement: 3 단계, 이미지 1/1
    • Locate screw labeled "KB" and remove.
  4. Sony Vaio PCG-31311L Motherboard Replacement: 4 단계, 이미지 1/3 Sony Vaio PCG-31311L Motherboard Replacement: 4 단계, 이미지 2/3 Sony Vaio PCG-31311L Motherboard Replacement: 4 단계, 이미지 3/3
    • Use a plastic opening tool tool to pry around the edge of the keyboard.
  5. Sony Vaio PCG-31311L Motherboard Replacement: 5 단계, 이미지 1/3 Sony Vaio PCG-31311L Motherboard Replacement: 5 단계, 이미지 2/3 Sony Vaio PCG-31311L Motherboard Replacement: 5 단계, 이미지 3/3
    • Once detached, tilt the keyboard forward, exposing a blue ribbon cable.
    • Place finger on black tab and pull back. Then, give a gentle tug on the ribbon cable and it will detach.
    • Once the ribbon cable has been detached, lift the keyboard away from the device.
  6. Sony Vaio PCG-31311L Motherboard Replacement, Motherboard: 6 단계, 이미지 1/2 Sony Vaio PCG-31311L Motherboard Replacement, Motherboard: 6 단계, 이미지 2/2
    • Use the plastic opening tool to pull back the ribbon cables attached to the motherboard
    • Use the plastic opening tool to pop up the black tabs and pull the remaining ribbon cables.
  7. Sony Vaio PCG-31311L Motherboard Replacement: 7 단계, 이미지 1/2 Sony Vaio PCG-31311L Motherboard Replacement: 7 단계, 이미지 2/2
    • Locate the LCD ribbon cable
    • Pull up and away from device to detach the LCD ribbon cable.
  8. Sony Vaio PCG-31311L Motherboard Replacement: 8 단계, 이미지 1/3 Sony Vaio PCG-31311L Motherboard Replacement: 8 단계, 이미지 2/3 Sony Vaio PCG-31311L Motherboard Replacement: 8 단계, 이미지 3/3
    • Close and flip over laptop.
    • Locate the WiFi network card.
    • Use the plastic opening tool to pry up the two connectors.
  9. Sony Vaio PCG-31311L Motherboard Replacement: 9 단계, 이미지 1/2 Sony Vaio PCG-31311L Motherboard Replacement: 9 단계, 이미지 2/2
    • Locate the 6 screws on the bottom and remove.
    • Remove the final screw in the center to release the motherboard from the case.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Tyler
회원 가입일: 08/24/16
45 평판
안내서 5개 작성하였습니다
USF Tampa, Team 1-1, Lacy Fall 2016 USF Tampa, Team 1-1, Lacy Fall 2016 회원
USFT-LACY-F16S1G1
5 회원들
안내서 10개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 9
전체 시간: 1,546
