주요 콘텐츠로 건너뛰기
Sony Vaio PCG-31311L RAM Replacement
필요한 것
  1. Sony Vaio PCG-31311L RAM Replacement, RAM: 1 단계, 이미지 1/2 Sony Vaio PCG-31311L RAM Replacement, RAM: 1 단계, 이미지 2/2
    • Start with device closed, powered off, and upside down.
    • Locate 3 screws on the bottom plate and unscrew.
    • These screws do not detach from the plate.
  2. Sony Vaio PCG-31311L RAM Replacement: 2 단계, 이미지 1/2 Sony Vaio PCG-31311L RAM Replacement: 2 단계, 이미지 2/2
    • Use a plastic opening tool to pry up on the bottom plate.
    • Lift up and away from the device.
  3. Sony Vaio PCG-31311L RAM Replacement: 3 단계, 이미지 1/2 Sony Vaio PCG-31311L RAM Replacement: 3 단계, 이미지 2/2
    • Locate the 2 clips on either side of the RAM chip.
    • Push both of them out and away from the RAM chip. The RAM chip should pop up.
    • Slowly remove the chip from the device
    • Make note of which side the slot is on in order to correctly reinstall the RAM chip.
  4. Sony Vaio PCG-31311L RAM Replacement: 4 단계, 이미지 1/2 Sony Vaio PCG-31311L RAM Replacement: 4 단계, 이미지 2/2
    • Repeat Step 3 on the other RAM chip
결론
Tyler
회원 가입일: 08/24/16
45 평판
안내서 5개 작성하였습니다
USF Tampa, Team 1-1, Lacy Fall 2016 USF Tampa, Team 1-1, Lacy Fall 2016 회원
USFT-LACY-F16S1G1
5 회원들
안내서 10개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 12
전체 시간: 949
