소개
This replacement guide provides step by step instructions with pictures to help replace your Sony Vaio PCG-3C2L battery. You may need to replace your battery if your laptop is failing to power on or if it is not holding a charge. To complete this replacement, an iFixit Opening Tool can be used, but it is optional.
Always check to make sure you have the correct battery. You can find replacement batteries here.
필요한 것
Turn your computer over so the bottom is facing up.
The battery should be in the top on the back of the computer.
