주요 콘텐츠로 건너뛰기
Sony Vaio PCG-3C2L CPU Replacement
필요한 것
  1. Sony Vaio PCG-3C2L CPU Replacement, Battery: 1 단계, 이미지 1/1
    • Turn your computer over so the bottom is facing up.
    • The battery should be in the top on the back of the computer.
  2. Sony Vaio PCG-3C2L CPU Replacement: 2 단계, 이미지 1/2 Sony Vaio PCG-3C2L CPU Replacement: 2 단계, 이미지 2/2
    • Initially, the "lock" button should be pushed all the way to the left. To unlock the battery, move the lock button from the left to the right.
  3. Sony Vaio PCG-3C2L CPU Replacement: 3 단계, 이미지 1/1
    • After unlocking the battery, hold the "release" button and push to the left.
  4. Sony Vaio PCG-3C2L CPU Replacement: 4 단계, 이미지 1/3 Sony Vaio PCG-3C2L CPU Replacement: 4 단계, 이미지 2/3 Sony Vaio PCG-3C2L CPU Replacement: 4 단계, 이미지 3/3
    • Keep the "release" button pressed.
    • Use the iFixit opening tool (or your hands) to lift the battery up.
  5. Sony Vaio PCG-3C2L CPU Replacement, Hard Drive: 5 단계, 이미지 1/1
    • Place the laptop so that the bottom is facing up.
  6. Sony Vaio PCG-3C2L CPU Replacement: 6 단계, 이미지 1/1
    • Using a Phillips #0 screwdriver, remove the two 3.5mm screws on the hard drive cover.
  7. Sony Vaio PCG-3C2L CPU Replacement: 7 단계, 이미지 1/2 Sony Vaio PCG-3C2L CPU Replacement: 7 단계, 이미지 2/2
    • Using a Phillips #0 screwdriver, remove the three 8mm screws on the hard drive casing.
    • Remove the black hard drive casing by pulling it off.
  8. Sony Vaio PCG-3C2L CPU Replacement: 8 단계, 이미지 1/3 Sony Vaio PCG-3C2L CPU Replacement: 8 단계, 이미지 2/3 Sony Vaio PCG-3C2L CPU Replacement: 8 단계, 이미지 3/3
    • Remove the hard drive by carefully sliding it out.
  9. Sony Vaio PCG-3C2L CPU Replacement, Fan: 9 단계, 이미지 1/1
    • Remove the six 8 mm edge screws from the back panel using a Phillips #0 screwdriver.
    • Remove the two 8 mm corner screws from the back panel using a Phillips #0 screwdriver.
    • Remove the four 8 mm middle screws from the back panel using a Phillips #0 screwdriver.
    • Remove the three 2 mm screws from the back panel using a Phillips #0 screwdriver.
  10. Sony Vaio PCG-3C2L CPU Replacement: 10 단계, 이미지 1/1
    • Remove the 6 mm screw from the battery holder using a Phillips #0 screwdriver.
    • Remove the two 4 mm screws from the battery holder using a Phillips #0 screwdriver.
  11. Sony Vaio PCG-3C2L CPU Replacement: 11 단계, 이미지 1/3 Sony Vaio PCG-3C2L CPU Replacement: 11 단계, 이미지 2/3 Sony Vaio PCG-3C2L CPU Replacement: 11 단계, 이미지 3/3
    • Remove the CD cartridge from the back panel by sliding it out.
  12. Sony Vaio PCG-3C2L CPU Replacement: 12 단계, 이미지 1/3 Sony Vaio PCG-3C2L CPU Replacement: 12 단계, 이미지 2/3 Sony Vaio PCG-3C2L CPU Replacement: 12 단계, 이미지 3/3
    • Using your hands, pull up the back panel about two inches up from the rest of the laptop.
    • Disconnect the black wire connector.
    • Remove back panel.
    • Pull up the back panel slowly so the black wire connector does not break.
  13. Sony Vaio PCG-3C2L CPU Replacement: 13 단계, 이미지 1/2 Sony Vaio PCG-3C2L CPU Replacement: 13 단계, 이미지 2/2
    • Unscrew the four 4 mm captive screws from the fan casing using a Phillips #0 screwdriver.
    • Disconnect the black/red/yellow wire connector by gently pulling on the wire.
    • Remove the copper colored fan casing that contains the fan by pulling it off of the bottom of the laptop.
  14. Sony Vaio PCG-3C2L CPU Replacement: 14 단계, 이미지 1/1
    • Remove the three 3 mm fan casing screws from the fan casing using a Phillips #0 screwdriver.
  15. Sony Vaio PCG-3C2L CPU Replacement: 15 단계, 이미지 1/2 Sony Vaio PCG-3C2L CPU Replacement: 15 단계, 이미지 2/2
    • Remove the fan from the fan casing by sliding it out.
  16. Sony Vaio PCG-3C2L CPU Replacement, CPU: 16 단계, 이미지 1/2 Sony Vaio PCG-3C2L CPU Replacement, CPU: 16 단계, 이미지 2/2
    • Place the flathead screwdriver onto the single screw of the CPU.
    • Upon pressing the flathead onto the screw, a small pop sound will commence.
    • Step 14 and 15 do not need to be followed if you are replacing the CPU.
  17. Sony Vaio PCG-3C2L CPU Replacement: 17 단계, 이미지 1/2 Sony Vaio PCG-3C2L CPU Replacement: 17 단계, 이미지 2/2
    • Upon hearing a pop sound, the CPU can be carefully pulled out.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Chloe Nelson
회원 가입일: 09/16/19
252 평판
안내서 2개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 10
30일 전: 34
전체 시간: 1,624
