주요 콘텐츠로 건너뛰기
Sony Vaio PCG-3C2L Hard Drive Replacement
필요한 것
  1. Sony Vaio PCG-3C2L Hard Drive Replacement, Battery: 1 단계, 이미지 1/1
    • Turn your computer over so the bottom is facing up.
    • The battery should be in the top on the back of the computer.
  2. Sony Vaio PCG-3C2L Hard Drive Replacement: 2 단계, 이미지 1/2 Sony Vaio PCG-3C2L Hard Drive Replacement: 2 단계, 이미지 2/2
    • Initially, the "lock" button should be pushed all the way to the left. To unlock the battery, move the lock button from the left to the right.
  3. Sony Vaio PCG-3C2L Hard Drive Replacement: 3 단계, 이미지 1/1
    • After unlocking the battery, hold the "release" button and push to the left.
  4. Sony Vaio PCG-3C2L Hard Drive Replacement: 4 단계, 이미지 1/3 Sony Vaio PCG-3C2L Hard Drive Replacement: 4 단계, 이미지 2/3 Sony Vaio PCG-3C2L Hard Drive Replacement: 4 단계, 이미지 3/3
    • Keep the "release" button pressed.
    • Use the iFixit opening tool (or your hands) to lift the battery up.
  5. Sony Vaio PCG-3C2L Hard Drive Replacement, Hard Drive: 5 단계, 이미지 1/1
    • Place the laptop so that the bottom is facing up.
  6. Sony Vaio PCG-3C2L Hard Drive Replacement: 6 단계, 이미지 1/1
    • Using a Phillips #0 screwdriver, remove the two 3.5mm screws on the hard drive cover.
  7. Sony Vaio PCG-3C2L Hard Drive Replacement: 7 단계, 이미지 1/2 Sony Vaio PCG-3C2L Hard Drive Replacement: 7 단계, 이미지 2/2
    • Using a Phillips #0 screwdriver, remove the three 8mm screws on the hard drive casing.
    • Remove the black hard drive casing by pulling it off.
  8. Sony Vaio PCG-3C2L Hard Drive Replacement: 8 단계, 이미지 1/3 Sony Vaio PCG-3C2L Hard Drive Replacement: 8 단계, 이미지 2/3 Sony Vaio PCG-3C2L Hard Drive Replacement: 8 단계, 이미지 3/3
    • Remove the hard drive by carefully sliding it out.
결론
Chloe Nelson
회원 가입일: 09/16/19
252 평판
안내서 2개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 3
30일 전: 19
전체 시간: 714
