주요 콘텐츠로 건너뛰기
Sony Vaio PCG-41216L Display Replacement
필요한 것
  1. Sony Vaio PCG-41216L Display Replacement, Display: 1 단계, 이미지 1/2 Sony Vaio PCG-41216L Display Replacement, Display: 1 단계, 이미지 2/2
    • Remove the covers for the two 3mm Phillips head screws at the base of the screen.
    • Make sure the device is unplugged and turned off before proceeding to minimize the possibility of electrical damage to the device.
  2. Sony Vaio PCG-41216L Display Replacement: 2 단계, 이미지 1/3 Sony Vaio PCG-41216L Display Replacement: 2 단계, 이미지 2/3 Sony Vaio PCG-41216L Display Replacement: 2 단계, 이미지 3/3
    • Use a metal spudger to separate the top cover on the back of the screen. It will be a long, thin plastic section that has the SONY logo in the middle of it. This enables the disassembly of the rest of the screen frame.
  3. Sony Vaio PCG-41216L Display Replacement: 3 단계, 이미지 1/2 Sony Vaio PCG-41216L Display Replacement: 3 단계, 이미지 2/2
    • Use the metal spudger on the sides of the frame to remove it from the screen.
    • Remove the four 3mm Phillips head screws that secure the screen to the exterior of the laptop.
  4. Sony Vaio PCG-41216L Display Replacement: 4 단계, 이미지 1/2 Sony Vaio PCG-41216L Display Replacement: 4 단계, 이미지 2/2
    • Carefully remove the screen from the supporting frame and lay it down on the keyboard of the laptop.
    • The wires connecting the screen to the body of the laptop will be exposed and fragile. It is important to proceed with caution.
  5. Sony Vaio PCG-41216L Display Replacement: 5 단계, 이미지 1/2 Sony Vaio PCG-41216L Display Replacement: 5 단계, 이미지 2/2
    • Locate the ribbon cable connecting the screen to the rest of the laptop.
    • It may be necessary to remove an adhesive seal in order to proceed.
  6. Sony Vaio PCG-41216L Display Replacement: 6 단계, 이미지 1/3 Sony Vaio PCG-41216L Display Replacement: 6 단계, 이미지 2/3 Sony Vaio PCG-41216L Display Replacement: 6 단계, 이미지 3/3
    이 단계에 사용된 도구:
    구매
    • Use a pair of tweezers to remove the ribbon cable from the screen.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Elmar Charoensaengsanga
회원 가입일: 03/15/18
384 평판
안내서 2개 작성하였습니다
댓글 한 개
content de voir qu'il ne faut pas démonter l arrière du pc pour retirer la broche de l'écran merci pour ce topic
Serge Wilhelmy - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 5
30일 전: 25
전체 시간: 890
